wildebus
I did have a suspicionIt just makes a handy terminal post.
No, if it works leave it alone. I used to get bullied by the wiring/assembly inspector at Racal Thorn in Wells. She wouldn't let me remove any equipment from the factory unless it was to her standard. Funny really as they were one of our subcontractors and I guess that made me her inspector. That said I wasn't supposed to be doing their work, but when I had senior military officers pleading for kit I had to get it sorted.That is very neat indeed
I have just this morning disconnected just about EVERYTHING in my installation to redo. Your cabling is putting mine to shame! (I would post a pic of mine but it would be X-rated for Horror) It's all going to be connected the same again, but look a lot tidier and look more logical now the setup is virtually final (still waiting on my custom programmable VSDR-200 (200A Voltage Sensing Disconnect Relay) as the final piece for the Hybrid Battery but that should be fairly out the way from the rest anyway - hopefully will be programmed and tested in the next week ready to ship to me)
I'm redoing mine primarily to remove some bits and try and get better cooling (I didn't notice before but the 4th battery I added a few months after the original installation is very close to the EasyPlus exhaust vent which I think is both partially restricting its airflow (it was getting too hot to touch when charging at a high rate) and causing the battery to go over 40C with the hot air pushed right at it.No, if it works leave it alone. I used to get bullied by the wiring/assembly inspector at Racal Throne in Wells. She wouldn't let me remove any equipment from the factory unless it was to her standard. Funny really as they were one of our subcontractors and I guess that made me her inspector. That said I wasn't supposed to be doing their work, but when I had senior military officers pleading for kit I had to get it sorted.
BTW, I wouldn't have shown her this board, she'd have condemned it.
Looking sexyJust when you think your under control, you end up adjusting things. In an effort to progress this project I decided to make blind leaps based on no experience. Don't do it. Even though I had dimensions and CAD drawings of parts it didn't work. I've had to juggle a few things around.
Make sure to have the bits to juggle with.
Next, connectivity! I have or will have at least five VE direct devices. Three VE direct ports on the Cerbo. So three of them can be taken up with three of the four mppt's. Only three of them will be regularly used for the three arrays of solar panels. The fourth is for an optional external panel. This I think will have to have a VE direct to USB cable. Next is the smart shunt, this again is VE direct. I wonder if the blue tooth will have the level of adjustability the display had? Or can it be set up via the Cerbo? Anyways this will need another VE direct to USB cable, but with an extension cable as the batteries could be up to five meters away. The calorifier will have to be switched via the relays on the Cerbo as the smart shunt doesn't have one.
This is a screenshot of my VRM dashboard with the sections in dotted lines and what devices drives each one when it is connected.I've put 24 volts to the board and connected to the VRM portal. All it's telling me is that's it's OK and Inverting with 24.39 volts. I guess I shouldn't be expect much?
I never had any joy with getting a display working on the Pi. like you elude to, you have to mess around with the setup for the Pi and change some code.New HDMI cable turned up today, but still no display from the Cerbo. Does the HDMI port need enabling?
I've plugged the display into a pi, still no display as I haven't configured the pi for it. Though the display knows it's connected to something.
Is this with the different screen?Yes life from the pi even without a driver, but nothing from the cerbo. So how we do get the cerbo out of headless mode and in turn get me out of that mode also?
