Phantom
It certainly doesn't, but one scenario does not fit all!Works for you and that is good.
Doesn't change the facts.
Obviously written by someone trying to sell a smart battery charger.As I already said ...
Don't agree? No problem. Your choice.
I will (or rather I will give you an example of an explaination via a link) why they are different ...
Do You Need a Power Supply or a Battery Charger? -
The terms “Power Supply” and “Battery Charger” are often used interchangeably, but they perform distinct functions. A power supply is designed to supply a constant voltage to a load. As the load requirements change, it continues to supply a fixed DC level. A true battery charger generally...apxonline.com
A true battery charger generally supplies a regulated current, first to charge the battery, and then switches to a regulated voltage mode. This is specifically required for Li-Ion chemistry where overcharging is not only damaging to the battery cells, but can also pose a possible fire hazard. A smart battery charger will not only never overcharge cells, but can also monitor battery temperature, switching off a fast charge when certain parameters are exceeded.
A power supply used as a charger cannot do this, and will continue to pump energy into a battery regardless of its condition; fully charged, battery fault, or shorted cells.
In order to achieve maximum battery service life, a properly designed charger should always be used to charge cells.
Does an Alternator best match the description of an Battery Charger or an Power Supply as described above?
Which one would be better for your battery?
Answers on a Postcard to wherever you want (not me, as I already know the answer to this particular one)
Sometimes it's better to stop digging....rather than to continue to try to justify a badly worded post, and personal opinions/beliefs presented as facts.
And won't be bothering any more.A tad unfair Ricc. He may not use flowery language, but I think his technical advice is generally well respected on here.
Why be put off by one unhelpful comment ?And won't be bothering any more.
I want you input so dont hide, a lot of your advice i have taken on board as regards to charging and solar regulators, folks have opinions right or wrong.And won't be bothering any more.
I guess it was your turn for pork exposure.And won't be bothering any more.
The trouble is , if something works it much be right?
Working well and efficient, is another story.
That would be a shame, as I believe 99% of us (often the less vocal ones!) appreciate your experience & expertise (and I say that as a qualified electronic engineer with 40 years of designing systems for military vehicles).And won't be bothering any more.
I've also seemed to arrive at that conclusion whether cost effective or not!If you have solar, you have the chance to finish off the absorption stage. Now this is where I think the money is worth spending. A real MPPT solar charger with adjustable voltage settings.
Looks like these batteries have problems with quality consistency, reading the reviews some have lasted four years and some will not charge after only a few hour of use. I suppose you takes your chances.I have just read all the real reviews for these batteries on eBay. I would recommend that you DO NOT buy these batteries as they are reported to be poor quality and they appear not to honour the guarantee.
Yes, constant use is the key to battery longevity. I've had a Yuasa 110 ah leisure battery in my T4 for eight years but its my everyday vehicle.Dont think batteries on a motorhome last long anyway purely to the amount of time the vehicles sit around idle and batteries do like to be worked - and point i'm making is the battery is barely getting used so will deteriorate faster than a getting used all the time
Good to see mention of charge cycles Warranty in terms of years is almost meaningless. The number of charge cycles a manufacturer claims is the best indication of battery quality. A poor quality battery may last a lot of cycles but a good quality battery is more likely to survive trouble free. However, accidentally flattening any lead-acid battery will seriously shorten its life.OK. I will give you an real life example involving the popular Banner Bull Batteries vs the Batteries I just got in yesterday to put in my Motorhome - so putting my money where my mouth is ...
Key Features of the two batteries
Banner Bull 100Ah Battery
£120
100Ah @C20 Discharge Rate
24.5Kg
2 Year Warranty
Requires periodic maintanance (topping up of water)
Requires external venting
200 Cycles when taken down to 50% Discharge (so it is expected that you can take out 50Ah 200 times before the performance is notably reduced and likely needs replacing.
12V 100AH RITAR AGM LEAD CARBON ULTRA DEEP CYCLE BATTERY
£190
29Kg
5 Year Warranty
Maintenance Free
No venting required
3000 Cycles when taken down to 50% Discharge (so it is expected that you can take out 50Ah 3,000 times before the performance is notably reduced and likely needs replacing)
So why buy the more expensive battery?
Well, the warranty is twice as long. It requires no maintenance (so pretty well fit & forget) and you can take out 50Ah every day the year for over 8 years. Do that with the Banner Bull battery and you will run out of cycles within 7 months. And the more expensive battery will also not complain too much if you want to take 80Ah or even 90Ah out of the 100Ah battery and still give you nearly 10 times the cycle count the Banner Bull will taking just 50Ah out.
To me, paying an extra £70 for those benefits is a no-brainer.
I am intrigued by this thread and wonder how people have battery problems?
My paired Numax batteries always last 6 years before showing signs of loss of efficiency.
My last van was 11 years old when I sold it with the original engine battery working fine. My current van is 14 years old and the battery seems to be original (if not, I have had it for nearly 7 years anyway). I have never had to buy an engine battery for around 30+ years.
Maybe an engineering background, an understanding of how things work and awareness of routine checks and maintenance has saved me a lot of work and expense.![]()
Good to hear from you Jim.
