mistericeman
Any dash lights or oddly flashing immobiliser lights etc
not that I have noticed, I will look againAny dash lights or oddly flashing immobiliser lights etc
I read all that thread and it seems over elaborate for such a small job but maybe that is it. Just a marker. Well 14volts this morning, crank x lots and still no go. Where would the fuel/water separator be then? anyone know?
Sometimes there is only one way to sort problems.It seems that every time I take the cover off the fuse/relay box something different happens. Is it, I thought, the fuel hose over the top that has to be moved over to get the box top off, that is the problem. So with that hose hooked up out of the way of the box cover I tried the engine and hey, it went. Still needed the ignition switch half back on to turn off the engine. Did the re-parking which allowed me to perform a much need clean of the drive. Turned engine off and on again and off to check but the third time I tried to start up it failed to go again. Weird. It will be some silly little thing, I am sure. I have not tried it again but I would be surprised if another tweak of that pipe does not have the desired effect.
An if you do a filter plenty of grease on seal an treads when reassemblingI have to say Witz; Diamond Dave's video was excellent
That's contaminated fuel so best thrown away I use a spray can of brake cleaner for cleaning most thingsI would put the fuel in a suitable pot and wash the housing in that to remove the contaminants.
Link was Here below diamond daves videoHeres the Amazon link in the second is a picture in the lower half of filter is the water drain its coloured white to drain water from filter with it in place you need to unscrew it gently while the ign is turned on this will push water out from the bottom of filter if theres any there
These filter holders split and dump diesel. I don't know if it was that the filter was changed before I had the van and incorrectly torqued down or they didn't use the correct tool for the job. But it split 2 years after I owned the van. I have heard of this problem before.Thanks Witz, seen; but I still don't understand what Yeo was saying. I was suggesting replacing the filter its self, not the casing, as the video shows; so this splitting business is not relevant, is it? Probably just me misreading something, I am good at that, misreading, that is.
I use this site https://tinyurl.com/app/myurlsBTW I did not recognise the Amazon link as a link. How do you do really short ones like that.
There's been 100's of reports of these filter housings failing some after a filter change some like Yeo's fail for no apparent reason after yrs of trouble free use. I've changed mine 3 times in 10 yrs as normal service using the tool you linked to using a torque wrench to reassemble with threads and seal well lubricated. I carry torque wrench + filter and assem tool and in case housing fails a length of fuel pipe and 2 jubilee clips to bypass the filterThanks Witz, seen; but I still don't understand what Yeo was saying.
