Deleted member 43466
hi
it will be the front suspension wishbone bushes worn.
I agree with Gordon I have no idea what he is talking about but he comes across as a clever chap.![]()
hi
Could be top strut mountings eddy,could be steering rack,could be a sub chassis loose ,the list goes on and on mate you know that esp wi taxis,roger is better getting a full alignment check done then take it from there imho
Take you’re wallet out the back cupboardThink weight on tail end has quite a lot to do with front end problems on mhs everythingis off balance so somthings got to give think any kind of upgrade on back suspension on a motor home shoul help front end drift
hi
i would get underneath with a tyre lever and check bushes before
alignment because if they need changing it will need realiged. how
is the tyre wear is it even.
Tyres are virtually new Ed, no sign of any wear yet.
Thanks for the advice.
Is it not that cheap vodka from Aldi that's causing it. Our hobby has a overhang I fitted air assist cost £300 made a massive improvement and lifts the rear 6 inch
I got mine off this guy paid extra £20 for dual gaugesPlease tell me more about the £300 air suspension.
Many thanks in advance.
Graham
Good luck Rog, mine started to wander when I fitted winter tyres, I was lucky that dropping the front tyre pressure cured it and there was nothing wrong with the front or rear suspension
This is what I found, previous tyres needed a high pressure on the front (Michelin X Campingcar tyres), new tyres needed the pressure dropped from 70psi to 45 psi, a huge difference but it worked, rear pressure was dropped from 80psi to 55psi, it is a nicer drive, quieter and a lot more feel to the steeringForgot to mention that the front tyre might just be too hard and that reduces the contact area and makes the tyres much stiffer in twist and flex. get the proper acle weight aa a weigh bridge then ask the tyre makers the correct pressure for that weighting. Mine is now 46 in the front when I got it it was 76. far too stiff but continental said drop it to 46 so I did it stopped a lot of my wandering.
Hope it is nothing to do with your missing electrical connection gissmo .
