trevskoda
That isn't the kind of piece of kit that you can buy from Toolstaion is it?
I think it's only the windscreen that's single glazed?Looks good,biggest problem will be the single glass windows losing heat and condensation,keep us up to date with picys,best of luck with build.
That's the best way. Strip all the panels off.
Mine was only single glazed.I think it's only the windscreen that's single glazed?
How do you get the side skirt around the batteries off? I had to cut it in half. Also had to cut the cab as the panel below the windows was rivetted to the front edge of the box behind the cab.That's the best way. Strip all the panels off.
Have you discovered the appalling way the engine bay isn't sealed from the cab? You probably know better than me now, but the stainless panels appear to be attached with double sided foam sticky tape!Any more pics, I'm converting an 05, surprised at the state of the box section inside and how difficult it is to remove panels.
Hadn't noticed that yet, upgraded from an 811 thinking I wouldn't have to deal with rust, how wrong was I?Have you discovered the appalling way the engine bay isn't sealed from the cab? You probably know better than me now, but the stainless panels appear to be attached with double sided foam sticky tape!
I'd have drilled the rivets out, I'm yet to tackle the battery box metal work. Go slow and think about how they connect stuff. It will save you time in the end.How do you get the side skirt around the batteries off? I had to cut it in half. Also had to cut the cab as the panel below the windows was rivetted to the front edge of the box behind the cab.
It will be worth it in the end. Just be careful about the steel you use and adding weight. Also the long runs can distort the body like you'd never imagine.Hadn't noticed that yet, upgraded from an 811 thinking I wouldn't have to deal with rust, how wrong was I?
Is it possible to contact you directly, can't see a way to message on this?I'd have drilled the rivets out, I'm yet to tackle the battery box metal work. Go slow and think about how they connect stuff. It will save you time in the end.
BTW welcome to stupidity, or heroics![]()
