Fazerloz
I did say towards.I think you would have to put a lot more than 1100 quid to go all electric.Id think triple that .
The locker on our 2019 campscout holds,The locker on our 2011 Campscout holds 2x13kg bottles of propane,
I keep hearing this 'when it needs replacing' trope. They don't wear out.A bigger shock when it needs replacing highest quote £1 500
So why did you do an unnecessary replacement.I keep hearing this 'when it needs replacing' trope. They don't wear out.
And they cost less than £1,500 to do a like for like replacement.
I know this because I did an unnecessary replacement.
They DO. You don't have to spend long at Charlies seeing some of the tanks removed from vans. Even had an ambulance rush in one day with gas leaking everywhere. Depends how well they have been looked after, both the tank itself and the straps/brackets run throughI keep hearing this 'when it needs replacing' trope. They don't wear out.
Modern steel and manufacturers aren't that busy Trev. Every tank sold has instructions about after care and inspections. End of the day manufacturers would probably say as the valves are rated 10 years that's all the tanks need to do. I have been there when 3 year old rusted through tanks have been removed though. I want to say one was 2 years old but I may be remembering that bit wrongIf the tanks and staps were shotblasted and painted properly from day one then the life would double, no one bothers.
We have 2 x 6kg installed and did 9 weeks in France , never had a problem finding LPG or with filling , a lot we filled at were unmanned stations ,pay by cardHi
We have a 2018 Globecar Campscout with diesel heating and use 2 x 6KG propane for fridge and cooking. The Calor bottles are fine for 3 to 4 weeks but we are looking to travel overseas for longer and so a tank seems to be a possible solution.
I have contacted Autogas 2000 who have suggested a 30L underslung tank and to use 1 x 6Kg propane as a reserve. Cost will be around £1100.
Any thoughts would be appreciated.
slightly underselling yourself a kg of lpg is just under 2ltrs i believe 1.95 so without being anal<your 38 ltr tank is over 19 kg nearer 20 i would thinkMy 38 ltr underslung tank equates to a 15 kg bottle I think.
Allowing for it has a 80% cut off a 38 litre tank holds 30 litres,slightly underselling yourself a kg of lpg is just under 2ltrs i believe 1.95 so without being anal<your 38 ltr tank is over 19 kg nearer 20 i would think
Did you do all box sections including inside doors a posts sills etc, steel rust from inside out as no primer or paint in there from new.I had our new Boxer dinitrol'd underneath, including the 30 litre gas tank. Do you think that will safely extend the life of the tank beyond 10 years?
Not at 80% Ken lolololslightly underselling yourself a kg of lpg is just under 2ltrs i believe 1.95 so without being anal<your 38 ltr tank is over 19 kg nearer 20 i would think
That's interesting, I filled up GPL many times in France and have yet to find a unmanned pay by card outlet yet, but I have found pay before you fill onesWe have 2 x 6kg installed and did 9 weeks in France , never had a problem finding LPG or with filling , a lot we filled at were unmanned stations ,pay by card![]()
Unmanned GPL pay by card are often at supermarkets. You usually have to pay at a specific nearby petrol/diesel pump and select the GPL pump before proceeding with the transaction.That's interesting, I filled up GPL many times in France and have yet to find a unmanned pay by card outlet yet, but I have found pay before you fill ones, so you have to guesstimate how much you need and pay upfront. Don't think you get a refund if you overpay. And on GPL on the Autoroute services where you had to prepay I asked 3 people where the prepay was and still couldn't find it, so left
