alcam
Good news for Barry . Not so much Michelle .already spoke to Baz.. it will be a pleasure to design some decent kit for him
Make him pay Tim![]()
4" square box I hope, we don't want Baz breaking italready spoke to Baz.. it will be a pleasure to design some decent kit for him
From what you've described you need to at least fix the supporting part underneath before simply replacing that flimsy plastic rail, if you don't it'll break again immediately. Ideally the support needs improving so that it doesn't break, once that's done I think the rail will be ok and be should last. Can you glue/screw a timber batten or Ali angle to the uprights?Both the runner housing and the supporting bit underneath have gone.
Some mothers do have them, here you go porky bed buster.View attachment 139419
Each side and fill left to right with new battons for bed.What am I supposed to do with them?
Each side and fill left to right with new battons for bed.![]()
6 inch nailsSo my engineer type neighbour has had a look and I sent some pictures over to Uncle Tim @zzr1400tim in Birmingham. Next door neighbour said some matching timber supports would work but maybe metal might be better. One thing I discovered is the angle is not 90 degrees on the underside of the bed runner structure. Perhaps it was designed this way to increase strength. Doesn't work then!
This is what Tim knocked up yesterday as a quick back of design. Probably in 50cm sections (easier to ship).
If I go this route ill just buy another strip of the original bed runner and fit the supports. Which will be best and look the best do you think. Steel / Aluminium or timber?
So why can't you just remove the plastic stuff and screw a length of wood in their place for the slats to rest on?
