Pudsey Bear
It just takes the weight off the top of the bearing so when you pump the grease in it goes all the way round but especially at the top where it will wear.I keep hearing different opinions. Some say both wheels off the floor at the same time, some say thats dangerous, some say just the weight off one at a time and Armitages the other day reckoned it didnt matter. Confused? Yep.
As a follow-up to the above I have now visited Fraser Brown.AL-KO Axle Repair and reconditioning
Fully remanufactured and reconditioned AL-KO rear axle as fitted to Hymer, Ducatto, Swift, etcwww.fraserbrowneng.co.uk
I suggest you consider carefully the above web page.
As manufactured the single nipple fails to direct grease to where it needs to go. In addition the bushes are badly designed.
I had my axle overhauled which in addition to a much better design of bush adds a further nipple to ensure that grease does go where it should to ensure axle longevity. The advice from Fraser Brown is to grease the axle much more frequently than AlKo recommend - ideally at 1,000 mile intervals which I have been doing since the overhaul.
In my case, as referenced by @TJBi above, a mistake during the reassembly process was made. This was determined several years later and having established this fault, Fraser Brown are going to strip the axle down again and rectify any resultant excessive wear. This is happening later this month free of charge. (I am combining a visit to their workshop with a Scottish tour.)
Of course, if you jack on the axle there is no point in jacking except for access.I was told 6 shots with the pump was enough with the wheels off the floor.
Any more grease might blow the bearings in the axle.
Use the jacking points and never the axle.
The axle is a hollow tube and will be damaged by jacking. Also, too much grease will cause pressure in the axle than can blow the seal, not the bearing.Of course, if you jack on the axle there is no point in jacking except for access.
