Pudsey Bear
You will be starving by the time you leave there though, looks like a portion of frites would be good by then, I bet by the time you've read this you'll be Googling "frites near me".
If like most garages they do more than one job at a time, some part may need to be made just for your van all sorts of reasons.
Bet you could kill for a nice bacon, sausage, egg n spam sandwich now though with loads of brown sauce the grease running down you chin D![]()
Bugger I want one now![]()
Pictures please...
My earlier, 2007, Ducato trip meter is hopeless.Later. Back home now. Rack looks good. Very different to my old one and it might take a bit of fettling. They changed the endless ratchet strap system a bit and Im not sure I like it but ill work on it tomorrow when my heads not fuzzy.
I figured out the trip metre, range etc on the van. Its all over the place. I found the average MPG and the current MPG. The second one I would expect to go up and down with your acceleration but the main average was doing that also to a lesser extent. With half a tank it was estimating the remaining range at 270 miles or something like that. So either thats wrong as well or the tank is indeed massive. I think the latter as its not dropped much the entire trip there and back.
The MPG is unbelievably optimistic. I suggest you take the figures with a bag of salt!
My 7m Hymer A class is a 2015 model with 2.3L Fiat 6 speed euro 5 engine and Alko chassis at 3850 kg and usually loaded to about this.
It has a 90L tank and has consistently over 8 years (reg new 2016) done 53,000 miles and gives 10 km per Litre or between 28 and 29 mpg, so range is about 900 km or 550 miles.
Regarding the Alko axle greasing, wheel off the ground and pump until pressure builds, between 5 and 10 strokes if done annually. Any more and I am told you are simply filling the axel tube.
PS fuel is brim filling and mileage reading over the years. No electronics to wonder about.
Davy
Yup mine too I've seen 42,8mpg on oursMy earlier, 2007, Ducato trip meter is hopeless.
Yup mine too I've seen 42,8mpg on ours![]()
But it mostly shows In the low 30s if I reset it every day.
I was told that you have to jack it up so wheels are off the ground & pump until it pushes out at the joint
AL-KO Axle Repair and reconditioning
Fully remanufactured and reconditioned AL-KO rear axle as fitted to Hymer, Ducatto, Swift, etcwww.fraserbrowneng.co.uk
I suggest you consider carefully the above web page.
As manufactured the single nipple fails to direct grease to where it needs to go. In addition the bushes are badly designed.
I had my axle overhauled which in addition to a much better design of bush adds a further nipple to ensure that grease does go where it should to ensure axle longevity. The advice from Fraser Brown is to grease the axle much more frequently than AlKo recommend - ideally at 1,000 mile intervals which I have been doing since the overhaul.
In my case, as referenced by @TJBi above, a mistake during the reassembly process was made. This was determined several years later and having established this fault, Fraser Brown are going to strip the axle down again and rectify any resultant excessive wear. This is happening later this month free of charge. (I am combining a visit to their workshop with a Scottish tour.)
