Good point is it acceptable to use a BBQ to connect a bottle with regulator to BBQ outlet ?I am happy with my two refillable bottles. Can’t see it getting to the stage where there is none in U.K. till I have gone and I can connect additional bottle via bbq point.
I had 1.4 toyota D4D . and friend had factory fit LPG Focus .We both agreed my Toyota Was the the best . up to 70 mpgI rememeber gas being the big thing in seventies then vanished but came back again about 10 years back,it did not grow as big because the gov was shoving diesel down are necks.
Technically it isn’t considered good practice risk of unseating one way seals that in turn can lead to leaks a lot depends on how it is plumbed ,,,but the simple answer to the simple question is it isn’t recommendedGood point is it acceptable to use a BBQ to connect a bottle with regulator to BBQ outlet ?
That’s my get out of jail option Baz for if my regulator packs up. As has been stated there is a pipe Gaslow do that screw-in to the fill socket. Will have to double check but I think I have a suitable pipe in the gas locker. I think Charlie said I did anyway lolGood point is it acceptable to use a BBQ to connect a bottle with regulator to BBQ outlet ?
Easy to do if you have a tap between regulator and distribution valves,one of the valve/taps out can also do as a gas in point if using a bottle with a clip on regulator,thats what i did so i can have a backup.Sharpie you have drifted off topic the question was backfilling With a donor bottle and regulator via the bbq point not the normal fill point with donor bottle .
Fwiw gaslow are one of the suppliers that suggest you shouldn’t
Bbq point an bottle regulator is my emergency gas route if bulkhead reg fails. Gaslow pipe is for connecting additional bottle to fill pipe utilising bulkhead reg.We are drifting off a little now.
If your regulator has packed up then the Gaslow pipe won't help.
Backfeed from a BBQ point using a basic on-bottle regulator (what is it, butane, propane, how many millibar, is it 28, or 37 or 30, is 30 the right number etc.) and that should work, but is highly inadvisable. Particularly if your regulator has failed. Who knows in what way ? Is back feeding it in a failed condition such a great idea ?
Just carry a spare regulator and the tools to fit it, ten minute job. If it is a Truma it will fail sooner or later. If a Clesse it will probably last forever.
Since in the UK we don't have to have gas inspections which should include quite detailed checks of the regulator and get some warning of problems, most of us continue regardless. Until it stops working. As they can do. Then we get frustrated, unless we have taken basic precautions and carry a spare just in case.
good info. ThanksGaslow make a connection that lets you plug a bottle into the fill point for this purpose.
This thing: https://www.gaslowdirect.com/Gaslow-Reserve-Cylinder-Connection-Hose
This would be the correct way to do it. It's quite neat because gas from the external cylinder will only flow if the pressure inside the refillable is less than that of the external one i.e. it is empty. Or conversely if the refillable had been filled with a butane/propane mix (typical abroad) but due to cold weather the propane had vaporised first leaving unusable liquid butane behind (has happened to me in Spain, level gauge indicating plenty left, but actually unusable), connecting an external propane cylinder would save the day.
AFAIK you don't need an internal gas locker to transport swappable cylinders, you can just chuck them in the back, then plug them in outside when stationary. Or swap them around with the ones in a gas locker. Otherwise how would anyone transport one ? There may be some limitation on how much you can carry, Eurotunnel for example are quite specific about this, but it's quite a lot.
It should work for those with underslung tanks as well.
By the way, underslung tank users can/do suffer the same cold weather problems with continental autogas, the butane content won't gasify leaving maybe 30% butane useless in the tank. This is compounded every time you re-fill there is less capacity to re fill, then more butane accumulates, and so on until basically you have a tank full of butane. You have distilled off the propane, leaving the useless butane behind. Which won't gasify until you have much warmer weather. By cold I only mean say 5-10 degrees. By zero degrees it can't gasify at all. And as it gasifies the tank becomes colder, a vicious circle.
Not usually a problem in Summer, but very real in Winter. In Summer I don't use much gas anyway, it is in Winter when I do, for heating, and continental autogas just isn't up to it. From experience.
Underslung tanks were designed for liquid takeoff for vehicle engines, which vaporise the stuff using engine coolant to boil it up, so don't suffer from this.
They have been re-purposed for vapour takeoff in e.g. motorhome installations by a few companies, but it's far from being a perfect solution, except maybe fair weather use abroad, or with UK propane autogas, when you can find it.
If you are using gas in cold climates you need propane, not a continental propane/butane mix. The best way to get this over there is swappable cylinders.
UK autogas is supposedly nearly 100% propane, so it's not so much a concern here.
Everything you might want to know about autogas: https://en.wikipedia.org/wiki/Autogas
