Weekend to be good so get the panels on and dont let anything foil you.![]()
Also try a sharpened paint scraper and heat gun.Got to get the old flexible panel off first Trev which is going to be a challenge.
Might have to find a cheese wire.
"Oblong"!!! you old fecker you.
Just for you Rob, cos I am a nice guy
I sent an email to Bimble Solar asking if it was ok to mount large solar panels on vehicles and if so what did they recommend. Here is their reply:
We highly recommend that all motorhomes/vans secure the larger framed solar panels (>120w) to the roof with bolts/rivets.
Normally customers use a bespoke solution (roof racking systems for example), alternatively we recommend using these aluminium mounts for riveting:
https://www.bimblesolar.com/extras/mounting/alu-long-mounting-bracket-black
One pair for 50w-175w panels, Two pairs for larger panels >175w, Three or more for the largest panels over 2m is highly recommended. Bear in mind judgement is important when using this guidance, each fit is different and you need to judge the best fit for yourself.
We recommend these rivets
https://bsfixings.uk/standard-al-st-domed-head?cat=159108
4.8 x 10mm x 500
formesolar.com
Does it need to come off at all Rob?Got to get the old flexible panel off first Trev which is going to be a challenge.
You just never hear it these days, still right of course.Would you prefer Rectangle Kev?
You are a pedantic old Bear sometimes!![]()
New thinking says it gets thinner over the top of the wing which creates a suction effect and lifts the wing, the thick heavy air under it then pushes up to help, the pressure differance on a jumbo jet is equel to a baby sucking on a straw which makes a wing more efficent thus saving fuel.
So you don't need wind deflectors Rob, the only problem that I see is how are you going to secure the baby sucking on a straw to your roof?Gosh! I hadn't thought of that when figuring out wind deflection over my solar panels Trev.
How silly of me!
having a deflector will make the top more aerodynamic and save fuel. It is estimated you will recover in fuel costs what you spent on aero aids in approximately 14.6 YearsI shall install the panels without a wing and see what the wind noise is like, I can always add it at a later date.
My immediate thought though it is not really shaped like a wing, more a deflector?
you can buy a 1,000 pack of plastic tile spacers for around £5. Much easier and simpler and dare I say more professional result?The min thickness is 1mm, I used 1mm thick wire to make sure it was at least that on the roof.
Those plastic tooth picks would work well too.
