barryd
My MPPT from Photonic universe charges the VB too, so worth having anyway at a similar price
Does it show the Watts / amps going in Kev on a screen or app?
A single output controller coupled with a decent battery maintainer trumps the dual output types IMHO because if the solar drops off desperately over the winter you get both batteries charged/maintained from EHU. You really need a decent battery maintainer though.Yes I am aware or that one Trev. I think it was discussed up thread. Ill talk to Merl about it as I think he has a solution for the cab battery. The Victron MPPT seems the more widely known though.
A single output controller coupled with a decent battery maintainer trumps the dual output types IMHO because if the solar drops off desperately over the winter you get both batteries charged/maintained from EHU. You really need a decent battery maintainer though.![]()
You can fit a 200amp relay and switch from hab batts to starter batts, you can use this for emergency starts linking all the batts up or to send power to the starter battery if required, this is in place on my van as if i have left van lights on im still able to start her up.Yes I am aware or that one Trev. I think it was discussed up thread. Ill talk to Merl about it as I think he has a solution for the cab battery. The Victron MPPT seems the more widely known though.
No. It doesn't take power from either battery, it feeds to them.......
EDIT: Now you mention it that Votronic duel charger you linked to earlier I did find reports on reviews that it can be a drain on the batteries in winter. Not sure how true that is.
ALL solar controllers consume a standing current, this varies considerably from model to model and is obviously very small compared to the solar gain during normal operation. In the winter over a prolonged period of no/low solar the solar controller can actually consume more power than the system produces and then it's effect will be negative. Very system and condition dependant though.No. It doesn't take power from either battery, it feeds to them
No drain here, mine keeps up or just holds in nov dec but has been charging from jan no bother, truth is my batts never go down.That sounds like it might need some heavy duty cabling Trev. The leisure batteries are right down the back and the cab battery right at the front on an 8m van. There is wiring in place to go to the engine battery already which is why I liked the idea of keeping that but it looks shite to be honest. The wiring thats been put in does not look great as Exwindsurfer pointed out. However What I do know is it works.
Ill see if I can get my head around Merls idea and take it from there. One of the controllers like Kevs or the one you linked to might just work fine. Im not fussed what goes in as long as it does the job.
It is crucial though that the cab battery stays topped up and if you saw my drive and that the only access is via the passenger door you would understand why.
"we would race to the wardrobe"Thats why I loved my old MPPT controller with the LED screen.If it was cloudy and the sun suddenly came out we would race to the wardrobe to check what was going in.
An app isn't quite the same though. Bit like a download comparted to a 12" Vinyl LP.
Votronic quote 50ma and 7ma in the same document so some contradiction but either way there WILL be drain Trev, I guarantee it.No drain here,
You could disconnect the panels altogether and you'd still have drain because the actual solar controllers consume power Kev.Peter sent me some diodes to stop that, but the panel had already fitted them.
Im always getting a charge even in the dullest of days, overnight batts sit at 12.7v then 14.4v daytime and falling to float at 13.7v, keeps me happy.Votronic quote 50ma and 7ma in the same document so some contradiction but either way there WILL be drain Trev, I guarantee it.![]()
A battery by its self losses power over a short time, stop baffaling Barry.You could disconnect the panels altogether and you'd still have drain because the actual solar controllers consume power Kev.
OK, here's a plan for you Barry.Ill see if I can find the thread about the Votronic drain. It was likely a faulty unit but I seem to think there was more than one person had the issue. With my old controller on the old van I had it a couple of times over Winter. I heard the Solar alarm going off in the van and when I checked the leisure battery had dropped to 10.5v. In the end what I did was I just pulled the fuse between the battery and the controller and isolated the leisure battery over winter. This cured the issue. With the Cab battery on the old van I just whipped off the negative lead under the bonnet. You can't really do that with a modern van.
With the current controller I have had no issues (so far). It must still use power though as it has two green flashing lights for both batteries which have flashed away all winter showing full. However to be fair there hasn't been a month where its not had a run out really.
This is why I was reluctant to change it as I kind of hate fixing stuff thats not broke but I appreciate its old hat. That said the bloke at off grid solutions "sniffed" at the proven differences between PWM and MPPT.
