Rumour
Not the Chinese government!Really? Governed by who, exactly?
YesDoes that count as Sizeist, Racialist AND sexist?
Well I guess that narrows it down slightly, one down, 194 to go eh? Anyone else you'd care to enlighten us it's not?Not the Chinese government
Can't believe it's took over a hundred posts regarding a Temu item before you appeared Chris! Where on earth have you been? Don't tell me.....on TemuIts all been said, we use Temu regularly ,ive bought multimeters,battery testers ,obds ,dash cams,ETC and been very satisfied with what ive received. Everything cheaper look at halfords for these all 3 times the price and made in china. With regards having my bank details ,they can rob me because ive got nothing much in the bank its all drawn out and in the safe,i dont trust the bank .I tried to get a lump sum out to buy a car ,they wouldnt let me have it,i had to speak to the fraud dept and tell them what i wanted it for. I had to lie and say its for materials for a new kitchen.
MERL, ive been bottling my homebrew and trying this new bread recipe.Can't believe it's took over a hundred posts regarding a Temu item before you appeared Chris! Where on earth have you been? Don't tell me.....on Temu![]()
UK Government pushing on with plans to cancel the £135 allowance below which no customs/import duties have to be paid. The move is designed to stop Temu and Shein undercutting UK businesses, but will not be introduced until 2029 because small businesses need time to adjust their systems; and because the UK Government will need to build a brand new IT System to process the millions of small shipments that will be affected by the change. Rachel from Accounts has matters in hand ...
Steve
The current-limited series charging isnt to revive a dead battery. Nothing can do that.The fact that there's no accepted and proven way of reviving a knackered lead acid battery proves that all the methods touted as being able to do so is almost certainly nonsense.
Given a choice between the Chinese government and the US government. I'd probably prefer the former to be monitoring.Not the Chinese government!
Must admit to never hearing about or considered imbalance in lead acid batteries. I guess the simplest method would be to check and charge each cell as required providing it had the busbars exposed. When you say series, do you connect more than one 12v battery up in series? If so why? I assume to balance more than one battery at a time? What sort of constant current is used? And what does that achieve that leaving the battery on trickle wouldn't? Isn't it essentially the same thing?The current-limited series charging isnt to revive a dead battery. Nothing can do that.
What it can do is rebalance the cells after one or more weak cells have been reverse charged by excessive discharging.
That can definitely bring a duff battery back from 'dead' but it will never make it like new.
Smart chargers are best, they make the battery do pressups.Must admit to never hearing about or considered imbalance in lead acid batteries. I guess the simplest method would be to check and charge each cell as required providing it had the busbars exposed. When you say series, do you connect more than one 12v battery up in series? If so why? I assume to balance more than one battery at a time? What sort of constant current is used? And what does that achieve that leaving the battery on trickle wouldn't? Isn't it essentially the same thing?
This is normally something only a battery dealer would do. It is certainly something I have only done when working at a garage.Must admit to never hearing about or considered imbalance in lead acid batteries. I guess the simplest method would be to check and charge each cell as required providing it had the busbars exposed. When you say series, do you connect more than one 12v battery up in series? If so why? I assume to balance more than one battery at a time? What sort of constant current is used? And what does that achieve that leaving the battery on trickle wouldn't? Isn't it essentially the same thing?
Trickle charging stops when the battery reaches a set voltage. This forces the current through whatever the terminal voltage reaches, because it is a constant current supply, not a battery charger.And what does that achieve that leaving the battery on trickle wouldn't? Isn't it essentially the same thing?
I used to race RC electric cars back in the 90s with my lad so I'm quite experienced WRT the weakest cell in the pack getting repeatedly hammered, cell matching was crucial.Trickle charging stops when the battery reaches a set voltage.
It's interesting how much 'old boys' knowledge is NOT out there on the net.Can't see any references to it on the net
You could do without a mains charger (we almost never use hookup) but you also have to fit a b2b charger. If you connect two lithium batteries and use a split charge setup, the much higher current will overheat your alternator enough to damage it pretty quickly.Just wondering.
If I swap to lithium thingy lifpoo batteries . My current onboard charger is not compatible but with two big solar panels on the roof do I actually need a mains charger. I think I might just do away with that altogether.
When lithium batteries were first introduced to leisure vehicles they came with an awful lot of mystery and caution. We now know a lot more about how lifepo4 works, what it needs and what it doesn't and the fact is it's way more tolerant of charging parameters than lead acid is, a lot of caution still exists as a hangover from those early times but the fact is you can use your mains charger with a couple provisos.Just wondering.
