wildebus
A little post about the a feature I noticed/discovered about the Victron B2B Charger which is kind of linked to this discussion ...
I am using a Remote Input Control feature on the Victron to disable it when the Cyrix VSR is active instead.
It tells you when that is the case when you look at the unit using Victron Connect
However, that is not the full story! Most of the time, the Charger will be off for a different reason ...
This is telling you the Charger is off as the Engine is off - or more accurately, the input voltage is under the turn-on threshold value.
Same Difference though? well, actually no! The Charger being off due to the voltage being too low is the first condition that is checked for and the Remote Input is secondary.
Does it matter? Well, it can do and this is something that can have an unusual effect.
If the Charger sees a voltage above the set threshold, it will try to go on. If it then sees it can't go on due to the remote input disabling it, it will not, of course, go on but ... it will remember it wanted to! And then, no matter and regardless of what the input voltage is at the time, it WILL turn on as soon as the Remote Input stop is no longer present.
If the Starter Battery is at a low voltage, the Charger will still turn on. It will not stay on for long as the turn-off voltage will be hit immediately, but the charger will still run for a minimum run time (around 2 or 3 minutes) regardless.
I found this was happening for the last few days as I have my van setup so the VSR is enabled for an hour each morning to let the solar do some Starter Battery boosting. This raises the Starter Battery voltage enough that the B2B turn-on threshold (currently 13.2V) is reached, and even though the B2B could not go on (as the VSR is on and it is one OR the other), it remembered it 'wanted' to. So as soon as the VSR went off, the B2B came on, and the Starter Battery voltage instantly dropped as it was suddenly supplying 30A to the Leisure Battery.
You see from the graph below at 11:00 the VSR goes off (the VSR is on from 10:00 to 11:00 each day), The B2B is no longer disabled and kicks on due to sometime in the last hour the starter battery voltage must have hit 13.2V even though it is below that at 11:00.
But does it really matter? Well, not really at the moment here, but depending on the voltage parameters you set on the Victron B2B, you could end up with a situation where you are putting a trickle charge into a Starter Battery as a maintenance thing and then wiping out that good work by taking a big slug of juice via the B2B, so it is something to be aware of I think, especially if you have an 'unintelligent' Starter Battery Maintainer such as a Battery Master, a Solar Charger that trickles a current as a secondary output or a basic connection.
I chose the thresholds on my Orion Smart-tr to be suitable to go on when the Engine starts, but I didn't really take account of the effect of the Solar on the Starter Battery - because I knew the B2B could not go on when the Solar was boosting the Starter - but I didn't realise about the Victrons apparent Memory.
An easy fix - just change the parameters (These are my current ones that I need to alter)
But if you are not monitoring the voltages, you would not realise this is happening and may wonder why your Starter Battery is apparently not being maintained despite having something in place to do just that!
