exwindsurfer
I do use a bucket now and then Barry but it does have holes in the bottom lololol
I did the same with my water tank dump valve Jeff, my tank is inboard and the manual valve was a right pain to get to so I mackled a 22mm central heating zone valve to do the job. It needs 240v to work it so I have to plug it in but there's no problem with accidentally dumping all our drinking water if a 12v switch gets accidentally switched onI had problem's be with my fresh water valve being stiff to open so I fitted this electric valve one flick of the switch and it’s empty no crawling around on the ground jobs a good un
Welcome to a Barry thread JeffF F S Barry are you that much or a worrit lolololol
Mine is 12v Merl and I have on occasion forgot to close it while filling up lololI did the same with my water tank dump valve Jeff, my tank is inboard and the manual valve was a right pain to get to so I mackled a 22mm central heating zone valve to do the job. It needs 240v to work it so I have to plug it in but there's no problem with accidentally dumping all our drinking water if a 12v switch gets accidentally switched on![]()
Just leave the tap slightly open.
You can still use the long hose just use a T piece off the tank one end to valve the other to your long hose if the valve pack up you still have what you already have jobs a goodun
But are you capable of doing it Barry![]()
He needs to find a way to get it on the bike.But are you capable of doing it Barry![]()
I am getting like you Barry a lazy sod![]()
