barryd
I claim the prize for the 100th post on a Barry thread.
Well done! The prize is you get to supply the cider while Merl fits it.
Bastard lololololI claim the prize for the 100th post on a Barry thread.
Can't understand it, why do you have to get on your knees or lie down? Can't you just bend over, turn tap and water runs out?
Edit: Or is it because my van is German and they thought things through?
It needs 240v to work it so I have to plug it in but there's no problem with accidentally dumping all our drinking water if a 12v switch gets accidentally switched on![]()
It's got a 13a plug that's easily accessible but tucked out of the way, I just plug it into a nearby 13a socket in the kitchen area and turn on the inverter. Wait until the trickling stops and unplug, turn off.It wouldn't use a lot of power.
If it is 5w (1/2 an amp draw) and is on for 15 minutes it would use less than 1/10th ah.
Could be that a £20 inverter would be up to the job.
Cut the pipe at the tank, and only use the sink and shower when parked on grass.
Is this the AI response, what software are you using, it's surprisingly accurate (Sorry this is a serious questionI've planned it all out.
Key Objectives
- Retain current manual tap for use when outside.
- Add electric valve in parallel (not in series) so you can operate it remotely.
- Switch inside cab wired to 12V supply for convenient control.
Parts You’ll Need
- 12V Electric Ball Valve(motorhome-safe, corrosion-resistant)
- E.g., DN25 (1") or DN32 (1¼") depending on pipe diameter
- Look for a normally closed or auto-return type
- Plastic or stainless steel body preferred
- Y-piece or T-piece connector(for grey waste outlet)
- Match your hose diameter (usually 28–40mm in Swift motorhomes)
- Short lengths of grey waste hose (same diameter as existing one)
- 12V momentary or latching switch(for dash control)
- Toggle or push button, waterproof optional
- Inline fuse + wiring (12V rated, 5A fuse usually sufficient)
- (Optional) Indicator light to confirm when valve is open
- (Optional) Relay for isolating switch from high current load
Installation Steps
1. Install T/Y Junction
- Cut the current hose after the manual valve.
- Insert a T or Y-piece connector.
- One leg continues to the existing outlet.
- The other leg will lead to the electric valve.
2. Fit Electric Valve
- Connect the electric valve using hose clamps and a short hose.
- Make sure it's mounted securely and angled for gravity drainage.
- Ensure the valve is rated for grey water (not fresh water only).
3. Wire to Cab Switch
- Run 2-core cable from valve to a switch in the cab.
- Connect to a 12V fused circuit, preferably ignition-switched.
- Use a latching switch if you want it to stay open until you switch it off.
- Optional: Add a relay if valve draws high current.
4. Test Operation
- Test valve open/close while grey water is in the tank.
- Ensure no leaks or backflow to manual outlet.
- Optionally, install a drain camera or indicator to confirm emptying.
Optional Enhancements
- Add a wireless remote switch (some valves come with remotes).
- Add a float sensor or tank level gauge to automate emptying.
- Add a valve open/closed LED in cab for feedback.
Example Electric Valve (for Reference)
- [AliExpress / eBay] 12V Electric Motorized Ball Valve (1”, DN25)
- Brand examples: U.S. Solid, SHURflo-compatible, or no-brand but marine/RV-rated
- IP65+ rated for outdoor use
Notes
- UK motorhomes often use 28.5mm or 32mm waste pipes.
- Check your grey tank's exact outlet size before buying parts.
- Make sure the valve can handle warm soapy water and debris.
- If space is tight, a solenoid valve may be more compact, but ball valves are more reliable for grey water.
Is this the AI response, what software are you using, it's surprisingly accurate (Sorry this is a serious question)
Did you download it then or find yours?
Bad signal down here on the south coast.Did you not read what I posted in the Autoroute thread? I used yours and said you have come to the rescue! Now everyone wants your link!Kev saves the day! Cheers.
Am I understanding ChatGPT correctly?
It seems to me that the manual valve would have to be open for water to reach the electric valve. If one leaves the manual valve open, water drains from the existing outlet and the electric valve is redundant. Surely the T- or Y-piece should be before the manual valve, or am I missing something?
- The other leg will lead to the electric valve."
