WOW Trev, page 2 before you posted your Votronic......... what happened?Swap it out for a votronic duo, it also puts a small charge into the starter battery.
Easy to wire up.
Has its own inbuilt fuse on input side.View attachment 143369View attachment 143370
His pute was running slow.WOW Trev, page 2 before you posted your Votronic......... what happened?
You're probably not far from a Screwfix, they do a cheapie for £10.99. Take some readings and post them, it'll help diagnose the problem. Maybe worth it if it'll keep you on the road?Ah well, thanks folks for your advice but I now think that it's kernaked, but hopefully our batteries will last our stay
First thing in the mornin is kick old paddy when he is half awake, ill be ready for you lot later on.His pute was running slow.![]()
I bet I can guess what you'll do........throw a f-kin charge controller at us all...... which one I wonder????I'll be ready for you lot later on.![]()
Always kick someone when he's down, less likely to kick you back.First thing in the mornin is kick old paddy when he is half awake, ill be ready for you lot later on.![]()
Yup, in the land of the rising frog,,.But we've just driven 70 klicks and fully recharged the batteries and now doing the campsite thing for the next few daysWhere are you just now? There might be a forum member nearby who can help (or are you Froggyside again?)
Thanks Trev, I'll have a look back homeSwap it out for a votronic duo, it also puts a small charge into the starter battery.
Easy to wire up.
I had the same problem with an expensive controller which originally cost over £100 with its associated display. I looked on Amazon and found a replacement for under £20 with built in display. I couldn’t believe how things have come down in price over the last 5 years. I suggest you order a cheap replacement like I did and use it as an aid to diagnosis. My van is now fixed and running on the £20 controller and I am tempted to order another as a spare!Hi folks and help, our solar panel controller has gone blank ,the van electric seems to be ok, any ideas or advice please
Peter
You have a problem with your van electrics it would appear, the solar controller might be kaput, and when on EHU your van is tripping the site, swapped polarity shouldn't cause the outside of your van to give you a jolt, I would suggest you refrain from using EHU until the van is checked.Now here's a howdydo, I think that it is due to swapped polarities because the van exterior gives me jolt when I touch it. Sadly my polarity tester is on the bench with the multi tester, could I be on the right track..
At that price it will be a old pwm unit and not worth 2 d.I had the same problem with an expensive controller which originally cost over £100 with its associated display. I looked on Amazon and found a replacement for under £20 with built in display. I couldn’t believe how things have come down in price over the last 5 years. I suggest you order a cheap replacement like I did and use it as an aid to diagnosis. My van is now fixed and running on the £20 controller and I am tempted to order another as a spare!
No it won't. Done it literally dozens, possibly hundreds of times, with no ill effects whatever.No that will bu==er up the control unit big time.
In that case, your amazon order history should lead you straight to the precise make and model.Anonymous, sorry, Amazon purchase a couple of years ago
