barryd
You need to bear in mind that there are only two wires Barry, one black and one red, and you would need to be pretty stupid to **** up, and although it would amuse me to say you are, you clearly are not or you would have done it all by now, at least buy the gear suggested that you need, basically a controller and a couple of cables, a 2nd battery and a MPPT controller then lay them out on the floor and just look at them, and you will figure it all out on your own (the best way) it's all very logical, even to a thick twat like me.
There are 100's of videos on how to do it all, just split them into different bite-sized jobs, not one larger one.
Take the controller you have, a bit of masking tape to identify which wires came out of where, mask ALL the red wires so they cannot touch the black ones, then fit the new one and put the wires back in, best to take the pos of the battery, but not essential.
For the new battery, place it next to the other, and just run red to red and black to black with the new cables, I prefer to feed into one battery and power from the other but that's just me and not entirely essential.
The new panel is not much more complicated, just two more wires to go into a junction box, then from there into the new controller.
Except its not quite the way to do it Kev as I have discovered in this thread. The controller is easy enough. I fitted the last one in my van and ran a load socket off it no problem. As was mentioned further up thread for two batteries the main positive goes to one and the main negative to the other then the other two on each are linked. There are already four connections to the current battery. Some of the leads are short and there is doubt about which connector leads to get. Changing the controller is easy enough but the batteries, im not so sure. I think it will be a bit of a pig.
