mistericeman
Whippets make great hot water bottles ....Thanks for the info .
Electric blanket ? Don't you have a dog ?
Downside is THEY don't like the cold either lol
Sadly No,Thanks for the info .
Hey Matey.
Because I didn’t have the luxury of Running up & bench testing the heater before installation, I just replaced the green fuel lines with white Nylon, Filled the Tank with Fuel, Primed the system, Connected up the Air intake (taken from inside the Fire Box housing I constructed to House the heater with Flor Vent), Fitted the Exhaust through a heat shield that went through the floor with High temperature Gunky stuff, Wrapped the whole lot in Furnace Wool, Tested the TWO strategically placed Co Alarms & the Single Combination Co & Fire alarm & Fired it up with me standing by with a Fire extinguisher & a mate with his thumb on the Remote Stop.
YES, it initially Smoked (Set the Smoke alarm off a I shxt Donuts for a minute or two) & Smelled for the first 10min while it burned off Oils & Whatever for the first 15min Test. I took the furnace wool out & inspected the floor, Walls & anything else I could looking for signs of Warmth or Leeks along the way. But the Initial 15min Test & The second 30min Test Both went without incident.
I then bit the Donut & Ran it for an Hour for the final test & subsequent inspection & noticed around 20 minutes or so into that there was absolutely NO smell at all, & has run Clean & Faultlessly for around 185 hours since often for 5 or 10 hrs at a time again without incident or smell from Unit OR Diesel tank.
Some I've fitted have smelled mildly (probably stuff used during manufacture like sealant or coatings on the gaskets etc )
BUT that's always gone after a 10 minute run on high .
The component types (rather than all in one 'suitcase')
Along with a turret mount are the only type that should be used in a campervan/motorhome situation as that allows all exhaust connections to be kept outside the vehicle ....
Though if you look on the Facebook Chinese heater groups there are lots that risk it using the all in one type ...
Mind there's a lot out there not recirculating cabin air ...which seems barmy to me efficiency wise .
I personally would go the the extra effort of connecting into the main fuel tank if you have a diesel vehicle ...for the convenience of topping the fuel up every time I fill the vehicle ...
Just makes life a lot easier ...AND less chance of spillage when filling a seperate tank .
Once upon a time ....I would've only fitted an eberspacher ..Thanks for the reply. Yes I think I will go for a connection to the main fuel tank as the smell from any diesel spillage inside the vehicle would make my wife extremely ill.
Having now done the maths (note the 's' Paul) I think that the idea of running an electric heater off grid is a none starter although I will always carry one in the van.
I have asked for a quote for supply and fit of an Autoterm 2D (formerly Planar) from a local dealer but I'm still researching. Ideally I think I would like an Eberspacher or Webasto.
I have a few options for location, could be external under the van, in the 'boot' (which would be under the double bed) or under the front passenger seat. Any comments re noise? Apparently the Autoterm is supplied with a silent pump so no ticking noises.
Still not safe for use in enclosed spaces IMHO as doing so can leave the exhaust connection with the possibility to leak ...On temu,getting cheaper by the day.View attachment 137824View attachment 137825
2kw is a physically smaller unit than the 5~8kw (almost half the size ;-) )
And as far as I can remember the difference between the 5~8kw units is down to pump size and htz settings in the menus .
Very easy to install in most vehicles if you have the space ...
Transits can be a pain to get access to the main tank ...
Easy on our 2004 ducato though as there's a hatch in the passenger side floor to remove the in tank pump/sender unit
Other than that ....
Hole in floor for the turret and some care routing exhaust etc
Rob, Liam at Coalition vans advertise supply and fit (plumbed into main tank) for £450According to the fitters the Autoterm 2Kw uses between .1 - .24 litres per hour depending on the setting I expect they exaggerate a tad though.
They have now quoted at £1095 inc. to supply and fit to my van which sounds a bit high to me given that they advertise that it is simple for self installation! I'm quite happy to install one myself apart from connecting to the Diesel tank.
