MERL
I think you'll find that's Caps locks KevBall cocks
Here's my thoughts Barry.
As campers go your use of 12v is pretty low and as you've come to realise you can manage without going for a huge lithium based setup. Having said that you've realised that you need more than 100Ah of storage to get you through those days with low/no sun, so 200Ah would probably be sufficient so adding another battery and then adding more solar IF needed makes sense on the face of it. Your problem is going to be when your batteries are a couple of years old and the capacity has faded to say 65% because at that point your 2 batteries are now only capable of storing little more than a single battery when it was new (like the one you're using at the moment) so you'll be struggling for capacity once again and therefore you'll be looking at replacing them quite regularly.
For a little more initial outlay you could buy 2 lithium off Amazon for just £170 each and just drop them in. Check the alternator charging current with a £20 DC clamp meter and if it's stupid high or stupid low (I doubt if it will be) then add a cheap B2B for £120 Inc cables.
You've now got a system that will effectively pay for it's self in just a few by years because you won't be swapping the batteries out every few years and will be upgradable with MPPT/ extra panels etc just like your LA system would have been.
Personally I'd upgrade to an MPPT anyway, it'll give you around 20-25% more solar and is a simple swap. There's loads of peeps swapping out their old MPPTs for larger ones as they install their mega lithium setups so you could pick up a cheap second hand MPPT with enough spare capacity for you to increase your solar in the future.
Lithium is now so cheap I really can't see the sense in buying and replacing Lead acid every few years.
Trouble with that is we are getting into the realms of stuff thats beyond me or that I would rather not mess with. If I go Lithium Im going for the system Off Grid Solutions proposed and ill let them handle it all. I really don't fancy me bodging it myself. I'm not messing about with Alternators etc and in the absence of anyone that can help me locally I think its best to either do what I am thinking and just whack in another 120 lead acid from Alpha or bite the bullet and go the whole hog. I think its worth trying my cheap idea first. If it doesnt work out so be it but its got to be better than what we had this year. In my experience the lead acid batteries we have had in the past worked pretty well for around six years before they started to go but then they went pretty quickly.
As for the controller I was always a big fan of MPPT and loved my old controller and really didnt like this one. Having said that, there is no doubt it does a good job and it charges the current battery pretty quickly. More importantly its connected to the engine battery also. It has a second output and it flashes when both are fully charged. I like that feature and as its already wired into the cab battery I think ill keep it.
MPP Solar Inc » PCM2012/3012 Series
www.mppsolar.com
I have the email of Eric who may be helpful Barry.
That would be fine.With my super interlektool mind, I don't see why you couldn't have two controllers with two panels, keep the existing setup as is, and then have a new MPPt one connected to the new panel & the pair of batteries.
I'll sit back while someone tells me why that won't work.
Excellent. I'm looking forward to seeing a battery made from Cava Cork.I think the point is if I'm doing it myself to keep it as simple as possible.
FLOWERY TWATSI nnever stay away more than one night, i have 2 90ah lead acids votronic regulator 200w solar, all running a 230v fridge with a smart 600w inverter, led lights and a tv which we never watch much, ph charging and some times a 400w plug in heater, again seldom used, but no way would this work in deep winter if staying off grid for more that 2 days max, each van owner must work out his use and sort to there requirements.
If this is way beyond you then book in somewhere LOL.View attachment 137284
That is simple, one panel controller and a battery.
Have you considered asking one of the members to help you fit it at a meet perhaps if one would be willing.
Votronic.I think the point is if I'm doing it myself to keep it as simple as possible.
You need to remember that if you can't get power into them, you can't get any out.
100w solar to 100ah battery is a genaral rule of thumb.
