barryd
Hi Barry we've got two 110amp lead acid which are 6-7years old with Votronic 350 MPPT and 150 watt solar which is still going strong. If we go on "extended" trips with no hookup I've invested in Ecoflow Delta2 with 220watt bifacial solar, the battery pack lives in the garage and the 240volt output plugs into the garage socket and feeds all the 13amp sockets on board and the solar can be manually adjusted to "follow the sun"!!!
I've noticed in all the diagrams and photo's no fuses are shown/mentioned. If you are installing another battery make sure you fit fuse next to battery terminal/s (to protect the wiring) and also take the positive from one battery to feed your hab side and the negative of the "other" battery to feed your shunt.
Best wishes
I thought it was just a case of wiring positive to positive and negative to negative and leave the existing hab wiring and solar wiring which is fused to the first battery. Are you saying there needs to be a fuse between the two batteries?
