barryd
Sounds a lot more useful than the typical 30cmOne reviewer reported that you can stop the flashing by pressing the right and left buttons at the same time David? Mine came with a 16ft armoured cable which will suit my needs for positioning,
It's actually dead easy to turn the backlight off, you just push and hold the 2 outer buttons, I've got mine off permanently.So was fitted out the way and not really visible. Quite a common complaint actually as the backlight stays on and when the batteries are charging it pulses on and off to tell you. It is a good monitor but that feature can be rather annoying.
Snap! The bright display was too annoying...It's actually dead easy to turn the backlight off, you just push and hold the 2 outer buttons, I've got mine off permanently.
I think this info only came to light after a whileIt's actually dead easy to turn the backlight off, you just push and hold the 2 outer buttons, I've got mine off permanently.
If you've got a 350A model I'd be interested David, don't need the shunt or cable, just the display.I think this info only came to light after a whileI started using the Victrons instead a few years ago with their connectivity and relay features swinging it for me.
If anyone wants one of these Alii Monitors, I have one, or possibly two, brand new 'old stock' ones available and I'll even throw in a shunt cable FOC![]()
Pretty sure the display part is the same on all three and you change a setting? I'll have a check of that as if that is the case, getting the smallest kit would be the cheapest option (IIRC, there are 350A, 100A and 50A shunts).If you've got a 350A model I'd be interested David, don't need the shunt or cable, just the display.
Pretty sure the display part is the same on all three. That's exactly what I expected too David but I purchased a cheaper 50A model because I didn't actually need a shunt at all, I used the long negative cable from the battery as a DIY shunt, (simply cant get the kit close to the batteries) All works fine EXCEPT the display stops increasing its display of current at around 85A and wont go any higher so I figured that the displays must come paired to their appropriate shunt? There's nothing in the manual or online about configuring the display to whatever shunt you've purchased either.Pretty sure the display part is the same on all three and you change a setting? I'll have a check of that as if that is the case, getting the smallest kit would be the cheapest option (IIRC, there are 350A, 100A and 50A shunts).
The 800W is "cooking power". I found my last 800W Microwave had an input power of 1150W. The new 800W Microwave draws 1050W.Well tried the 800 watts microwave today on full power for 6 minutes on the inverter, even though it's only 800 watts,it took just over 1385 watts out of the battery, it dropped from 100% to 96%, again checked for anything getting hot and pleased to say everything remained cool to the touch, except the microwave that was quite warm.
Hanks for the explanation David.The 800W is "cooking power". I found my last 800W Microwave had an input power of 1150W. The new 800W Microwave draws 1050W.
Some of that 1385W you are seeing will include other loads on the battery as well as the Microwave ... Lights, USB chargers, etc, etc. take those off the 1385W and that will give you how much power running the microwave took, and the difference between that total and the Microwave input power (say 1150W?) will give you the inverter overhead.
PS. ignoring any other loads, it didn't take 1385W OUT of the battery, it DREW 1385W when running. It actually took 154Wh out of the battery based on the 4% drop in SOC (just to pedantically more accurate). Running for 6 minutes when drawing 1385W, it should have taken out 138.5Wh. Difference from 154Wh will be down to rounding up of battery SOC on display.
Dave Phil has just a post up about Black Friday deals on said BATTERYS grab a deal mate if you are goung for itT
Bahh, don't beat yourself up about it. LFP is dropping in price continually and it's just a matter of time before they (or their equivalent) is selling for £799, a bit more time and it'll be £699! Just buy em, fit be em and enjoy em, no use waiting for the price to bottom because goodness knows when that'll happen, probably £1 per Ah? Guesses anyone?
