wildebus
What van have you got?I don't think I'd get a ready made rack long enough Annie.
if you can secure a rail either end, and stick it down securely along the whole length, then it will be pretty well fixed. if you could find a way to secure centrally a well that would be best. I would think you could go through the roof (the same as same the solar cables or TV ariel is) inside a cupboard and use a spreader plate or even a simple penny/repair washer inside. (if you do drill into the roof, watch out for any cabling mind! I made a hole in the last week in my roof and where I drilled it I found a pair of wires that I didn't expect. Use a Forstner bit and you can go carefully without risking cable damage. any other drill bit and you are taking a risk).
In my example, I purposely left a small gap between each panel to avoid a "wing affect". With your proposed panels you will have a very long area for "trapped air" so your front aerofoil to divert the air over the top is a good idea I'd say
That looks really nice RobYes I like that idea David.
The only problem I can see is that I can't get to the inside of the roof apart from at each end of the van to put a nut and washer. I could put rivnuts in or maybe even well nuts.
I will look into it thanks.
That looks really nice Rob. Slightly more effort needed than pieces of Ali angle but I'd say adopting a system like David's idea and planning for failure will guarantee the panels last forever so you'll benefit in the long run
One other thing I'd consider is giving the panels some support between the roof and the centre of the actual glass panel to stop it flexing/ocillating like Rolf Harris's wobble board, being shook and vibrated isn't something they'd be subject to on a house and constantly bouncing and flexing probably would do them a lot of good. A couple of large parts pieces of something semi rigid like polystyrene cut slightly undersize and fastened with a bead of Sika would work.
Just before hitting the 'post' button I proof read what I'd typed and it said :-That looks really nice Rob. Slightly more effort needed than pieces of Ali angle but I'd say adopting a system like David's idea and planning for failure will guarantee the panels last forever so you'll benefit in the long run
Aren't you installing a water misting system then Rob?just wondering if it might create a hot spot where the ventilation can't get to it?
Aren't you installing a water misting system then Rob?![]()
seen a sheet of plasterboard on a roofrack going down the road?Rob forget the spoiler, the idea is for air to go under to cool in both driving and stationery, 2 inces is about right, if you must install a deflector then place at the upper edge deflecting air over the top but leave the front under section clear.
Dont need to be forced just a air flow Rob, cool panels work better, hence the stick on flat jobs die after a few years, also look at home roof panel, air gap under them.Dunno about that Trev. You sit in a field for a week without air getting forced under the front and they seem to survive?
Im lucky as the roof nose on mine is higher than where the panels are, still not taken off as yet but im trying.Yes I know Trev. There will still be an air gap on the other 3 sides, just not at the front.
It's to stop the 'wing effect' as David said, so there is less stress on the fixings when doing 70mph on the motorway.
Thats not a nice thing to say about our RobHey Rob,
Remember thickness 'counts' when using Sika 554...Alec.
Hey Rob,
