trevskoda
Still require a regulator behind the cig socket, more expense which is not required.If you can charge via a dashboard solar panel through the cigarette lighter with ignition off, can't get much simpler than that. I don't like cigarette lighter sockets themselves (connection wise) so I'd probably wire into the back of it with an inline fuse and maybe a switch. Advantage of the cigarette lighter plug is it will likely have it's own glass cartridge fuse inside which you might wanna down rate to 5 amp.
I didn't mean your solar controller Barry, I meant your main power distribution unit, the one with all the fuses etc.I put the link on page one and some photos. Its this one https://www.mppsolar.com/v3/pcm20123012-series/
Yes there are various threads .outlets at the bottom of the MPPT Controller and I think there may be a spare two. Also a load socket which I run various 12v adaptors off.
Might be easier if I go and take some photos tomorrow or a video.
Cant find any details on that PMS4 unit unfortunately, they seem like gold dust. So don't know if both the cab and the hab batteries are taken back to that unit or if there is a split charge relay somewhere,
That reminds me .... On that age of British Motorhome, there is typically a pair of relays under the bonnet - one for split charge, one for fridge - with a D+ control signal. You could connect a maintainer there, spurring off either side of the relay. That would be literally a 10 minute job.possibly under the bonnet where again, both battery connections are available.
Looking at the first photo of th control box, the switch bottom right selects between using the Vehicle and Leisure battery, or turning the system off.
Assuming this is connected (not all features may be connected in some installations, but on a factory motorhome let's assume they are), then THAT is 99% sure the ideal place to make a connedtion for a battery maintainer.
You bring out a connection from inside the box for both +ves of the batteries, which must be in the box (just need to follow the switch wires) to the maintainer; find an earth inside that unit (there WILL be one) and those 3 wires go to the maintainer and that is the job done.
Now THIS is an important point .... The above is only true IMO if you are going to use a proper battery maintainer such as the Battery Master or preferable the Ablemail AMT12-2. I would not do it this way if just using a switch connection or physical joining of the cable (the "clive Mott" type setup). The Wires you are using mayb be small and could not withstand the potential loading if you leave then connected when starting the vehicle. The Battery Maintainere by design are current limited and their draw will be within the design limits of the cables in the box.
Getting a maintainer will be more expensive than the 'direct' method but is very much a DIY job on the above. The alternative of running cables if employing someone to do it will cost more and give you a worse end result.
That's a pms3 Kev.
If you get someone who is familiar with campers - and especially conversions (your kind of system is obsolete in terms of what is fitted to new Motorhomes, but in principle is very typical of most self-build campers), then it should be a matter of the guy saying "no problem, guv" and sorted inside an hours callout.Well spotted. Yes that rocker switch does exactly that. Left is the leisure battery and right is the cab battery and it does indeed work so there is a connection.
I agree with you that if its going to be done its worth doing properly and I think I would prefer to employ a professional. I am cautious for two reasons. I dont like fixing stuff that maybe dont need fixing. It could turn out I have a duff battery but it could be that my style of motorhoming is responsible for slowly depleting that battery and the cause of my iffy starting problems. There is also the age of the van and its components. Am I going to get an engineer in who takes one look and starts scratching his head?
There is nothing out there for free.That's a pms3 Kev.
Don't know what the difference is?
Getting slightly off topic, but some photos which could possibly help get a feeling of what to expect when working on this PMS unit (TBH, I think if someone is wary, these photos will reinforce that, but don't be frightened!)That's a pms3 Kev.
There must be a half decent auto sparky up there Barry.
It is terrible that even so long after the knowledge was really worth anything they still want to sell you the PDFs, info like this should be freely available to anyone who needs it.
