wildebus
Ok, a few comments ....I’ve recently installed a Dometic CRE80 in place of the old 3way in our camper.
We have just got back from 3 nights away to test it, the Victron Orion Smart 12 12 30 B2B charger and new 285ah deep cycle lead leisure batteries Ive installed work as expected.
We also wanted to see how long our Eco Flow River pro Lithium battery (62ah) will take the day to day strain of powering the fridge as it recharges fast off the generator whenever that is convenient/possible.
All works fine but I’m still unsure as to how much power the fridge is likely to draw on average as we saw it use 30ah and then 60ah in two days of similar use & weather conditions.
Anyone got some figures for actual battery use for similar dc fridges?
A typical decent Compressor Fridge will use around 1.5Ah/Hr average. When running it will be around 4A, but the compressor only runs part of the time, so it averages at around 1.5A.
In hot weather, the power consumption goes up notably - on the official figures, it can nearly double. For most people, that does not matter massively as if they are wild-camping, they typically have solar and the solar in hot (so sunny usually) brings in more power then when overcast and cooler. As you DON'T have solar, the increased consumption could be an important factor (so maybe as I suggesed, a portable solar kit could be handy?)
USING the fridge makes a remarkable difference as well. when I say "using", I mean opening door to take food out, put food back, etc. The official figures and most consumption data (including mine) will be based on the door kept closed. I have noticed that when I look at my power logging for the fridge, I can actually tell very easily when I load it up or do any kind of re-arranging - the 'cool' goes very quickly through an open door and much faster than you might imagine. I wonder if that was a factor in your 30Ah vs 60Ah power use days?
Now on power use, I found my Waeco 50CRX would run for just about 2 days on a pair of 100Ah Lead Acid batteries until they dropped to 50% - so that would be 100Ah taken out in those 2 days. that is around about the same as your findings by the look of it (90Ah in two days).
Now of course bear in mind you are not only running the fridge, but using lights or whatever. My 240V Compressor Fridge uses significantly less power per day than the Motorhome habitation system generally when I am using it, so my battery bank is not sized to support the fridge but using what I want to use. Unless you are very frugal, off-grid and with no solar, you will be using that generator a fair bit I would guess?
As you have fitted the Compressor Fridge where the old 3-Way fridge is, you could take advantage of the venting and fit a cooling kit if you think the fridge migght be getting hot and so less efficient?
I fitted a "proper" cooling kit to mine. When I say "proper" I simply mean a commercially packaged all-in-one kit with temperature-controlled speed control and a nice little control panel. You can obviously rig up your own more cheaply, but I decided to treat myself
I found the fans fitted perfectly on the Thetford mesh vent screen ...
