Mr and Mrs Tupcox
Whats the free standing heating ,hope not a open gas fire.In winter my electric use becomes minimal, l listen to radio off my phone, tv is minimal, heating is freestanding, hotwater is from the gas hob. At the moment there's still enough sun.
It sure is trev and I do not advocate using one but needs must.Ventilation is needed and after falling on it once and the burn scar to prove it I treat it with respect.I must add I was under the influence of alchohol when I fell.Whats the free standing heating ,hope not a open gas fire.
Chap we know was working in a open sided shed cutting wood with a garage oil burner running, he fell off his seat and other chaps could not waken him, doc arrived and pronounced him dead, carbon monoxide poisoning, be very careful.It sure is trev and I do not advocate using one but needs must.Ventilation is needed and after falling on it once and the burn scar to prove it I treat it with respect.I must add I was under the influence of alchohol when I fell.
Will be carefull,Ive had the same setup about nine years.Chap we know was working in a open sided shed cutting wood with a garage oil burner running, he fell off his seat and other chaps could not waken him, doc arrived and pronounced him dead, carbon monoxide poisoning, be very careful.
Would you not fancy a diesel blower which is a good job.Will be carefull,Ive had the same setup about nine years.
I put a 3kw chinese heater in during summer and its brilliant .The point of the free standing gas fire is it doesnt use electricity and when the solar isnt providing enough power thats when I use it,also it gives instant heat wich is what I need sometimes for short periods of time,in a morning for half an hour before going to work,a couple of hours on a night before bedtime.Would you not fancy a diesel blower which is a good job.
Is it the we ones with a gas canister inside.I put a 3kw chinese heater in during summer and its brilliant .The point of the free standing gas fire is it doesnt use electricity and when the solar isnt providing enough power thats when I use it,also it gives instant heat wich is what I need sometimes for short periods of time,in a morning for half an hour before going to work,a couple of hours on a night before bedtime.
Yes a flexible pipe to bbq point, l must stress this setup not considered appropriate.Those small propane garage heaters dont look bad ( cheap enough ) saves blower on heating - if you had a quick connect fitting within the van although safety would be an issue - or put hose through small opening to bbq point - individual choice though
What power are your solar panels ? we need to upgrade our single 110 lead acid was thinking of getting lithium but if 2 lead acid and decent solar panels do the job I'm all for saving moneyWell that didn't take long dirty grey morning .
On isle of wight .sun is not showing his face .just odd blue sky , as the clouds pass by.
And bingo my cheapo batteries are all most done.
Thank you my cheapo solar system View attachment 88310and regulator..
You dont need to buy the best to enjoy free power..
OK. I will give you an real life example involving the popular Banner Bull Batteries vs the Batteries I just got in yesterday to put in my Motorhome - so putting my money where my mouth is ...Being of little knowledge regarding batteries what are the benefits of buying an expensive 100 amp battery versus a cheapo 100 amp battery.
Do they drain at the same rate ?, 100 amps is a 100 amps regardless of battery cost I would have thought. Or Is it just that they will last longer before failing, have a longer warranty, charge quicker, etc, etc.
Not much unless you buy a varta/bosch one which will not disintegrate internally as fast, remember that if you go down below about 30% it will shorten their life.Being of little knowledge regarding batteries what are the benefits of buying an expensive 100 amp battery versus a cheapo 100 amp battery.
300wWhat power are your solar panels ? we need to upgrade our single 110 lead acid was thinking of getting lithium but if 2 lead acid and decent solar panels do the job I'm all for saving money
Regards Steve
What kind of Split-charge system have you got? that is the first thing to know. You may well have a B2B type of system fitted (even older vans sometimes did)I think in order to decide what to replace my two Banner batteries with, I would like to know whether an agm type would need an expensive upgrade to the alternator output, such as a B2B, being a 2002 van it's certainly not a newer smart alternator. Also would the fact that the vehicle battery is non-agm affect the split charging?
I am beginning to think that the efb types might be more straightforward to charge.
The only relay I've seen is under the cover in the centre of the engine bay. I saw this mentioned in another thread on here this week, it's common to the Sevel type vans of that era. I don't know whether that is the relevant thing, and I'm not sure how to find out. As far as the other charging sources go, although the solar controller doesn't have a specific setting for agm, there is an option to set "user settings" for the voltage so presumably that would be OK. When on hookup I have a multi stage smart charger which presumably charges at the rate appropriate to the battery typeWhat kind of Split-charge system have you got? that is the first thing to know. You may well have a B2B type of system fitted (even older vans sometimes did)
Next, bear in mind that a basic relay setup will not really look after any battery properly and efficiently anyway, as an alternator is not a battery charger.
It is a charger, maybe just not the best at peaking power, but better than nothing.What kind of Split-charge system have you got? that is the first thing to know. You may well have a B2B type of system fitted (even older vans sometimes did)
