Markd
You'll have to go up to 225-75-16 to get the load rating, they are only 5mm wider on each side and a so should fit on the rear (presumably that's your 2.4T axle) without any major issues.It's 'worse' than that, I've also just had a online chat, they don't make a suitable campervan tyre as fitted to my van, in fact nobody does as the CP specs don't allow the tyres to be made strong enough in 215/75-16 to take the 2400kg axle loads. I knew this before going online, but thought I'd try, they ended up offering the Cross Climates for all season use, but claimed they where not suitable for motorhome use.
I have an Alko axle and had to tie back the handbrake cables.
No problems about changing gear ratios on the rear axle of course.
I do have to admit to a slight cock up in that I ordered the tyres online with Kwik Fit and they'd fitted them before I realised that I'd managed to order standard rather than Camping - doh! The availability varies so if using KF (prices online are v competitive) may need to check back a couple of times - voice of inexperience speaking
Having said that they are a 10 ply rating and have performed fine. However their max pressure is lower than CP tyre - 85 rather than 90 if I remember correctly.
