wildebus
Little tip on if the valve cap or sensor gets seized on a valve stem ... a Dremel is perfect for removing.I had the cheap ones, and they worked okay. But a couple seized onto the tyre valve and had to be carefully cut off. So not using them now.
You use the Dremel to make a little slot indent on the cap - can do this on the top or side. Only needs to be around a mm or so deep. And then use a slotted screwdriver to put in the cut and twist and it will open up and free itself off the valve thread.
