mistericeman
It took a years of technology to do that , ic engine goes up and down and round and round just like the first one ,not a lot of progress in over a 100 years
Stick a detroit 2 stroke in it
Few years ago sons water pump needed doing and i told him to change it easy enough ( lumbered myself then ) - but it was a twin cam renault clio pig of a job no room and it took me 2 days i think - twin cams are a pig of a job as a lot will knowLucky you, my van the whole front end had to come of, then the rads and intercooler.
Glad i'm not doing itMy car will be done in summer, proton with a renault 4df 16 valve with little room round it, may be an engine out job, not looking forward to the job.
Used to do our cambelts, the old Cavaliers where a doddle, last one I did was our old Astra, a PITA, I did the recommended (at that time) of replacing belt, tensioner, idlers, a week later the pump started going and needed replacing.Few years ago sons water pump needed doing and i told him to change it easy enough ( lumbered myself then ) - but it was a twin cam renault clio pig of a job no room and it took me 2 days i think - twin cams are a pig of a job as a lot will know
I thought they were pushrod engines, most here were with ither a 1100 or 1300 cc xflow engine.Easiest one ever was on my 1972 Ford Cortina 1.6 GXL, did it out on the road in front of the house in no time at all![]()
We had 2ltr unless they were savage ones 3 ltr jobbies few and far betweenI thought they were pushrod engines, most here were with ither a 1100 or 1300 cc xflow engine.
Exactly like this one and the reg was GTD 99K, wish i`d kept it.
Later models had larger spray holes if I remember correctly, good engine though with a few tuning bits on1600/2000 ohc 'Pinto' was cam belt....
And a crappy pressed steel spray bar to lube the followers
Oil spray holes used to block and wipe out the followers/cam in short order.
Burton used to do some very nice tuning gear for them.
Yes, the later ones had the holes enlarged, Ford did same on the later twin cam 8 valve engine, holes where too small and got blockages.Later models had larger spray holes if I remember correctly, good engine though with a few tuning bits on
And there wear build of cast iron which is way out of date from ww2.Yes, the later ones had the holes enlarged, Ford did same on the later twin cam 8 valve engine, holes where too small and got blockages.
