Fisherman
Very important advice when using compression joints. I also use ptfe tape on the male screw thread for added integrity. But you would seriously have to over tighten to cause a leak, and under tightening can lead to the connection eventually working loose. The torque setting for Mobile gas settings are normally a bit higher to allow for this.Do not overtighten the connections. Each end of the pipe is fitted with a gas compatible washer which will crush if overtightened.
The dealer who helped me yesterday told me this is the biggest cause of gas leaks. The fitting should be hand tightened, then nipped up about a quarter turn.
He told me that there is a Truma tool which is made of plastic which will break if you try to overtighten the connections!
