I fitted one of these last year:
LFD230 Varta Professional Dual Purpose DC Leisure Battery 230Ah (930230115)
LFD230 VARTA Professional Dual Purpose Leisure Battery <i>Innovation with Purpose, Premium Experience, Powerful History</i> VARTA was founded in 1887 Germany, and was established fully in 1904 by delivering the first electric vehicle battery, famously driven by Thomas Edison. Soon after, VARTA...www.tayna.co.uk
It's the largest capacity battery in the highly thought of Varta/Bosch silver framed range.
Cheaper than the Red Bull, but Alpha Batteries don't do them.
Sorry but yes It will. whatever amps would go into one battery will go to each battery in a two battery set up. whatever you use is split across two battery’s so it will recharge twice as quicklyThe time to charge will not be halved.
An analogy.
If you had two water tanks rather than one and emptied 100 litres of water it will take exactly the same time to fill from the tap ...
Ha ha, don’t need that one sorting. The only proviso being you have the capability to put the charge back inRelax. I've asked Commissioner Gordon to fire up the Bat signal. Hopefully the Dark Knight's alter ego, millionaire socialite @wildebus, will drop in from the shadows and sort this out.
That assumes your battery charger has also doubled in size (if the same amps go into BOTH batteries as went in one with a single battery)
Like this one? https://smile.amazon.co.uk/dp/B01G2...0-pcomp-feature-scomp-wm-5&ref=aa_scomp_srdg2
Doesn't look too bad a price or am I missing something?
i have to disagree with you on this one you don’t need to cover your roof with panels like Phil .I only have 400watts of solar but because I can tilt them up to 90% I was getting between 15 and 17 amps up at the frog meet .I can’t understand why more of you don’t tilt your panels .I don’t have to tilt them at all in the summer.Fitting solar panels and heading for Scotland this time of year will not work unless you do as Phil has done and cover the whole of the roof. You will be lucky to get 1Ah out of a 100w solar panel this time of year. The further north you go the worse it gets. Having flat panels on the roof is also a no no. Panels should be pointed at the sun if you see it. Panels should be near vertical and tracking the sun this time of year.
The answer is an Efoy fuel cell. Not cheap but the small one will churn out 3A 24/7 which is 72A per 24H which should be more than enough for your needs. You will save on weight as you only need a small battery bank and you don't need to go for expensive lithium batteries. When you consider how much your solar panels are going to cost. Add on a good quality solar regulator. Add on the cost of extra batteries and wiring. Don't forget all the weight that this adds and you soon realise that a fuel cell works.
You should have enough for one you just saved £4000 on your new MH and got an extra £1000 for the Swift crap.
Simple Jeff, lack of access. Of course ladders would provide that but something else to carryi have to disagree with you on this one you don’t need to cover your roof with panels like Phil .I only have 400watts of solar but because I can tilt them up to 90% I was getting between 15 and 17 amps up at the frog meet .I can’t understand why more of you don’t tilt your panels .I don’t have to tilt them at all in the summer.
I understand that with you Neil.Simple Jeff, lack of access. Of course ladders would provide that but something else to carry
I do keep thinking about a folding panel but don’t think I would like leaving it out when I am not near the van as rarely on proper sites.I understand that with you Neil.
How about a square panel mounted on the back of 800mm satellite dish, tilt and turn as required?Could the tilting panel be moved up and down with air rams or electric motors,should be doable.
That wasn’t tilting them though was it Steve?I got 0.11kW off of my panels today![]()
