Have we got an update on the TPMS from the original post yet ?
Paul
Under a day left on the OP ebay offer.
It was a very cheap way to implement a mandatory TPMS requirement as needed no extra hardware, but the limitations are certainly there, and why aftermarket systems are usually better!Most modern cars do that, including mine, but unless you plug a diagnostic tool into the OBD port, it doesn't tell you which tyre is soft (even though it knows).
The only ones I've seen previously have sensors inside the wheel that don't last, are expensive and have to be programmed to the car if you fit new ones. PITA. The last was an insignia...
Managed to get into battery by using grips on the case and then turning anti clockwise with the special tool supplied. Batteries are included will set it up next day or so.
Look forward to your review on them, once you have them up and running.
