trevskoda
I will have you know young Trevor that we don't have grime round here, maybe curry powder and joss sticks
Well you can only put that on a foreign bike chain.:lol-053:
M/cycle chains these days are sealed and oiling them atracts dust/grit which wears them out faster.
A new Royal Enfield motorbike maybe ?
In the last 30 years chains have been o ring sealed and only require a wipe over with a almost dry cloth containing lite oil.
In days gone past you removed the chain and boiled it in a tin of duckhams chain oil wiping dry on outside before refitting to bike,hope this clears things up regarding chain and lubs.
Taken from Regina Chain's maintenance manual:
"In the O-Ring chains, lubrication is provided by grease sealed in the working area by O-Rings.
However, it is still necessary to provide periodic lubrication to the chain.
Lubricant between rollers and bushings will decrease friction and heat, and will improve the efficiency of the drive, extending chain and sprockets life.
Lubrication also keeps O-Rings in good condition and protects the metallic components from rust and corrosion.
Use SAE 80W-90 mineral oil or motorcycle chain specific lubricants safe for O-Rings."
The full manual can be seen here.
I hope this clears things up regarding chain and lubs
Regards,
Del
That's not quite true. X ring and O ring chains have grease 'trapped' in them but still require occasional lubrication. We use non o rings on our KTMs and they require constant lubricating. Obviously a lot depends on the conditions you use your motorcycle.
Scrambling lol? You sure did start out early on bikes. However, hats off to those old scramblers getting their bikes round a track. Loads of power (500 two strokes, ***), wooden brakes, crap suspension. Heroes.
Think you misunderstood , £26 for 900 ML but only used 150 ML, 1/6 th
The thing about chains is that there are two separate things being lubricated:
* the roller bearings inside each link (which probably do have sealed-in grease) .
The trouble with a rubbery coating is that damp can get trapped inside it.
