wildebus
Yes indeed, but you don't need to remove the wiring from the area any more than you need to remove the gas pipe.You shouldn't run the compressor fridge from the 12 volt supply going to the 3 way fridge...
For myself, When I swapped over, the gas pipe stayed and the 12V wiring stayed just in case someone in the future might want to retro-fit a 3-way again for some weird reason.
It should be wired straight to the battery ...the fridge should come with these instructions.
I did not state this previously due to a new compressor fridge coming with instructions...( that was my thinking)
I can't see any reason to remove the gas pipe..
Simply blanking it off is enough..or as said use for a outside barbecue point.
