Wully
Cheers Merl done as you said. I’m just running a test put everything on in van to deplete the batteries down below 90% before I plug the mains back in. I’m just wondering these batteries hook up to the Bluetooth app individually and seem to be running as two separate entities on charging and discharging with a bit of electronics. I wonder if that 10amp on each battery would double up. Sorry if this sounds daft but I’m as thick as chit when it comes to this. Van had two 100amp gel batteries I just ran all cable as they were attached to these. I have a victron shunt and the BMV battery monitor should I connect this for a better reading of the overall state of batteries. I’ll get you a big pint when I see you next. PromiseWithout a poke around and taking measurements with a DC clamp meter it's hard to say what's going on Wully.
The charger is supposed to deliver 22 Amps BUT according to the manual it goes into 'standby' mode after ten hours. Not sure what standby mode entails but it could equate to the 10 Amps that was being displayed on the images of the App?
You'll have to make a judgement as to whether your existing mains charger is up to your requirements and get it swapped out for a higher power model if need be.
Someone will be along soon to tell you that the charger is intended for lead acid batteries and you shouldn't be using it for lithium.... don't worry it'll be fine. Set the battery type switch to the upper setting (PB) and don't leave it running for days on end once the batteries are charged and you'll be fine. View attachment 150906
