wildebus
Just as an FYI and make things even more confusing for you .....I was thinking autosleeper may have added the carver capacity to get the 108. I dont use the carver as we just boil the kettle so its turned off so does not fill. I have tried it on a 20liter drum would not work on the empty same as my tank. No quality stars untill I got 5litres in it. Yeah noticed on my venus os pi it can show percentage and litres. And adjusting the height and bottom on venus you can get it to read something usefull if you remember when the mopeka gets under 12 litres it goes off and you still have 12 litres. But the lower quantity is what I really wanted the mopeka foryeah my tank overflows from the top it has vent holes but if you turn the hose off straight away it soon stops.
Thanks Mike
I now have a working Mopeka after changing the battery and it is fitted to the bottom of my Gaslow cylinder, which is an 11Kg bottle, which is what? 20L? Now that bottle is effectively empty (it is not sending any gas to applicances) and the Mopeka App reports the capacity as 3%, which is under 1L of fluid, so I don't think there is a general minimum value for the sensors to read a volume, especially considering their most usual use is LPG tanks and they are invariably much smaller than a water tank.
I've got some Duracell 3V 2032 Batteries coming tomorrow which are meant to have upto 70% longer run life so will fit one of those in the Fresh Water sensor and then do some testing.
