Our cheap battery!
Whoops. lighting and little else.With the lithium i can just disconnect,easily pick it up with one hand and drop it off at friends house ,do a days work and pick it up fully charged.No more rationing leccy for me now.
Can the van not charge it.
Time for a progress report on the two Probat 100 amp batteries I purchaced in september 2020,post #9,They were lead acid at about £65 each.
I was wondering about my Probat too now it is 3 years old, though linked to an even older Yuasa LB. They still seem okay and do not normally drop below about 85% as we are very low power users and solar tops them up. I'll do a capacity test out of interest when I get chance. (y)
My probat voltage readings were very high usually 13v hours after it got dark,but a 4 amp load would see 11.9 after three hours use.For the price I was happy with my purchase.
Just an update: Our Probat battery is still good after almost 5 & 1/2 years, it is coupled to Yuasa battery which is 2 years older than it. There are no obvious signs of reduced capacity, they balance out together and both still have low resistance. Our power usage is quite low so the batteries have an easy time and previously haven't really gone much below about 80%, but now with an extra solar panel fitted the current daily dip in use is only from about 95% to 90% and back up again though slowly gaining. I expect that they should be good for a few more years yet.
I've said this times and you've demonstrated my point somewhat. It's impossible to have one battery at a higher voltage than the other when they share the same connections. They MUST balance and mixing batteries of different capacities isn't an issue.
Now...tell me how you measured the resistances?
