Geek
Because it looked very rusty. Turned out it was very very solid metal but that was hard to tell until it was off.So why did you do an unnecessary replacement.
We all make mistakes. Learn from mine.
You have to take 20% off the water capacity to allow for ullage space, then half the result to get the kg LPG capacity.. That is 15kg.slightly underselling yourself a kg of lpg is just under 2ltrs i believe 1.95 so without being anal<your 38 ltr tank is over 19 kg nearer 20 i would think
£25/30 should pay for blasting and a coat of zink rich 2 pack epoxy followed by a good coat of poly 2 pack finish.Because it looked very rusty. Turned out it was very very solid metal but that was hard to tell until it was off.
Very expensive, and powder coating is no use for outside stuff, best only on internal banisters or chair legs etc, out side is eithe 2 pack or cloranated rubber.Not a price I recall around here, I had to have a 10" three way valve repainted as it was black not potable water (water industry) blue. £150 power coated, no blasting. £30's the admin fee.
As I understand it all later model sevel vans are now galvanised. Some argue that additional treatments like Dinitrol and Lanoguard etc are a waste on these vehicles as rust wise they are already well protected.Did you do all box sections including inside doors a posts sills etc, steel rust from inside out as no primer or paint in there from new.
Sevel models from what year, the van I've recently sold, was 2011 and I had to have rust holes in the drivers door sill welded over, the rest looked OK, I kindly filled the sills with Dinitrol after welded up, for the next ownerAs I understand it all later model sevel vans are now galvanised. Some argue that additional treatments like Dinitrol and Lanoguard etc are a waste on these vehicles as rust wise they are already well protected.
Sevel models from what year, the van I've recently sold, was 2011 and I had to have rust holes in the drivers door sill welded over, the rest looked OK, I kindly filled the sills with Dinitrol after welded up, for the next ownerView attachment 149772
Yes. This one rusted from the inside out, the perfect paint started to discolour, orange rust slowly, it wasn't damaged, then, came back from a MOT and the bugger pushed his screwdriver though to make the hole, which wasn't even mentioned on the MOT cert.Galv or not stone chips need attention ASAP or it will rust away.
Not hot dip galv, its electro plate type and may give a we bit extra, you must protect with a anti rust like lanolin/dinitrol etc.As I understand it all later model sevel vans are now galvanised. Some argue that additional treatments like Dinitrol and Lanoguard etc are a waste on these vehicles as rust wise they are already well protected.
Just for info if anyone doesn't realise:Not at 80% Ken lololol
I think they quote 15.2kg
the larger the tank you have room for the better (and the more you save on refills over bottles )Hi
We have a 2018 Globecar Campscout with diesel heating and use 2 x 6KG propane for fridge and cooking. The Calor bottles are fine for 3 to 4 weeks but we are looking to travel overseas for longer and so a tank seems to be a possible solution.
I have contacted Autogas 2000 who have suggested a 30L underslung tank and to use 1 x 6Kg propane as a reserve. Cost will be around £1100.
Any thoughts would be appreciated.
That's where a refillable system comes into its own.While in France we carry 2 13kg bottles of propane (we use Primagas) and when we arrive in England we head straight to my sister's house where I swap them for a 13kg Calor bottle (red - propane). This seems to be fatter and I don't think we would be able to get 2 in the gas compartment. Makes life a bit difficult trying to guess when it will run out. Last year we paid around £60 for refills but so far this year the first was £28 at a builders' merchant in Liverpool. When it needs replacing I think I will phone round to get the best price available locally to wherever we are.
My old tank was 100 litres. I replaced it with a 70 litre because the old one hung a bit low: it was by far the lowest point of the van.I've not got why peeps have a big tank tbh, you end up using more, if you have more, we've been away a week and used 18l, but had the fire and oven on every night but one, topped up 3 times, may need another to get home.
There are always edge cases. You aren't suggesting replacing tanks before three years, are you?I have been there when 3 year old rusted through tanks have been removed though.
