New Inverter has stopped the R/C of TV 🤔
YeoBlade
I have a new LG TV 230v which was powered by a very cheap ciggy plug in inverter when off grid, however I have now upgraded the OE equipment with a 300ah Li battery and Renogy 3kw inverter. This works fine and tested to 2.5kw without issues on heating/cooking appliances
So plugged in the TV and can't get it to turn on with the remote, pressing actual button on TV and on it comes BUT the R/C wont work or do anything. Plug TV in grid mains or cheapo inverter and works perfectly ☹️.
I'm assuming its RFI or similar from the inverter, however even if I keep the inverter powered on but power the TV by another source it doesn't have a R/C problem, so the interference must be transmitted into the TV by the inverter supply ??
I have bought and waiting delivery of a Power Filter for Interference Attenuation in Electrical Appliances.
Any thoughts please our Electronic buddies out there ? @merl @wildebus et al
https://www.ebay.co.uk/itm/127466307923?var=428561661852
PS Just thought I must earth the inverter, maybe 🤞
Just a thought, but I wonder if the new inverter is a smart device (a power saver) that won't supply power to the TV unless it actually 'asks' for it. By turning the TV on at the switch, you're activating the circuit but the TV in a 'standby' state might have been 'put to sleep' by being logically disconnected by the inverter and so won't be able to respond to commands from the remote?
It does run the TV fine, functions perfectly except the remote control wont work.
The inverter is a bypass one so grid powered up all working good, but pull the grid power the TV stays on, but the remote control doesn't then operate it 😕.
This is definitely one to ask on the official Renogy FB Group.
One of the unpaid voluntary mods there is unbelievably obsessed with the group and seems to answer everything to the point he single handedly is virtually doing what should be Renogys job of providing technical support!
I just hope it isn't faulty because anyone that has ever had anything faulty will know just how torturous and drawn out their warranty process can be!
would that be Jonty?? Yes I pasted it up their (but it was blocked as I cut and pasted from here and it was full off Victron links ☹️😀😀)
I do have a 12v TV, in the bedroom.(And the remote works 😄)
12v TVs have limited choice and features being generally poorly value for money.
Mine cost £25 at car boot sale and it has corrie and emerdale, what else would a woman want to see. 😂
One way to cut and paste without links is the use Ctrl+C to put into the clipboard and Ctrl+Shift+V to paste.
I have a Toshiba TV at home and every so often the remote refuses to work. All I need to do is remove the batteries, wait a minute, put the same batteries back in then it works as normal. Maybe a long shot but worth a try?
First thing I did was try new batteries, then contacted the TV seller as it was broken. Until I realised the I can literally sit there with the TV on and turning on the EHU the remote works and turning EHU off the remote doesn't. The pass through inverter switches to power mode that quick the TV doesn't even flicker when I cut EHU
I would try fitting ferrite baluns onto the wires going in and out of the inverter. Their inductance might suppress the RF being broadcast down the cables.
Not guaranteed to work, but cheap and an easy DIY job.
Yes! That's solved it, (everybody likes an update 😁) just pop it in the project box and sorted, though annoying that this was required in the first place.
Only just seen this Julian. What an odd problem, obviously something to do with the high frequency inverter switching noise on the 230v output. Normally TV remotes work by infra red not radio waves so intriguing why the mains waveform would affect the remote?
Glad you sorted it and good info👍
As the invertor is sold as being suitable for use in a vehicle it seems strange that it is producing electrical interference, AFAIK it should meet the relevant regs.
Very disappointed with C.S. Tec support response time, having to take the DIY approach 😢😉😀. Was a strange one, I contacted the TV supplier as it was 'broken' and was about to return it, then I tested R/C with the phone camara saw it was working and back tracked what changes I'd made. The power supply! I read elsewhere someone else had a similar problem with a Renogy Inverter and LG TV combo which was reassuring in a strange way.
@YeoBlade
FYI Jonty might have had a bust up with someone in Renogy, he’s been removed from the management teams private chat group in messenger and has announced he is leaving the official Renogy Group, in some ways thats a good thing he and another mod James Richard’s were always having rather weird arguments which I found awkward at times.
He has set up his own group on FB so is still out their obsessively helping
@YeoBlade
Renogy official (like many) censor bad press, they removed my post about this problem. Also after a week of the LG TV working OK with the RF in line filter, it Stopped working again 😫. So I have swapped the TV with our house bedroom Samsung TV which is fine. I'll have a look at Jonty's group 👍He is KEEN!
