Hi All
My habitation door lock cable has stretched.
Apart from main Rapido dealers, does anyone know of companies that can make cables to order?
You send them the old one as a copy.
Soldering the cable is the best way to enable cutting or, if possible, fit it, then cut the excess off after.Hi again.
I have just spotted on Amazon some z cable ends so as my cable has stretched around 12 mm, perhaps I can cut off the end shorten the cable and fit a new z end.
2 questions- Should I buy one that needs crimping on or one which secures with a grub screw?
What is the best way to cut the cable to avoid fraying?
Yes it is but the outer has stretched so if I were to wind it out the cable would be even more curved.At the risk of stating the obvious I see an adjuster there that is fully wound in.
That's as it's meant to work isn't it?Yes it is but the outer has stretched so if I were to wind it out the cable would be even more curved.
If you can get the inner adjusted enough that should do the job, any bend in the outer is irrelevantWear and tear I guess. The van is now 8 yrs old but actually we don’t think that the bottom latch has ever secured properly.
I just think that if I shorten both cables by 15mm we should be back in business.
That's what the bottom adjuster is for, to effectively shorten the cable. If there is a nut under the cable adjuster undo that then hold the top hex on the adjuster whilst tuning the nut next to it clockwise down the thread. this will shorten the cable. When done if there is a nut under the bracket tighten it back up to the bracket.I don’t think I can without shortening the inner.
