barryd
You can't argue with the laws of physics, not even if you're an 'Expert' from Vanbits or Off-grid solutions.
My guess is that Hank1 reported a slightly higher voltage than Hank2 would have done with the same battery swapped between the 2 vans, this would be simply down to inaccuracies of whatever you are getting the readings from. What did you experience that would contradict my idea Baz? I've read every postand can't find anything, in fact it would explain everything.
The old display panel in my van reads nearly 200mv higher than it should, another van (or plug in voltage display) could easily read 200mv low, that's nearly half a volt difference between the 2 vans more than enough to completely throw you off target WRT operating efficiency.
Tell you what, fully charge your battery, switch on the telly, lights etc, and anything that you can plug into the 12v side that'll take a constant current indefinitely ( not a laptop or phone charger because that will slow down/stop taking current when it's full). Note how long they've been running before you reach the point where the voltage readings would suggest to you that you would have to be conservative with usage going forward (You seem to suggest 12V?) and then continue to run the equipment as before. I reckon you'll get considerably longer than you think before you go flat.
Yep, it'll be 1 full discharge cycle down to nearly zero but it won't kill the battery and you'll now have a much greater knowledge re your actual battery capacity.
Hey! If you owned a DC clamp meter you could actually measure the current at the same time and get a much greater insight into what's going on and what to expect going forward.
All I used on the old van was the MPPT controllers screen which told me the current voltage on the old van. All I know is that when we swapped from a 120ah lead acid to a 120ah AGM it made a world of difference and Im talking about when the lead acid was in good fettle. I was told up thread that a 120ah AGM would make no difference and would discharge at the same rate as a 120ah lead acid and that does sound logical. After all its 120 amp hours so its usage is measured in time right? No, not right. It most definitely lasted longer. This new 120ah I would say replicates the usage of the original 120 lead acid I had but as you suggest it could be two things. It could be there is more draw on the new van and it could be that the two methods to measure the voltage are not the same. Dunno.
I don't think the controller is the issue. (if there is an issue). Its holding the charge for long enough once its charged hence the idea of trying just a second battery.
