r4dent
Have you checked the setting on the solar controller?
It may be set to prioritize the vehicle battery.
From the op it's a 12v fridge, not a 3way.
Is the fridge Compressor (Electric only) or absorption (selectable between battery / gas / mains) ?
If you don't know ..what is the make & model?
The fridge is a compressor (electric only) - it seems the coachbuilder does not like fitting gas.Yep, hadn't thought about that. With the base vehicle being a Boxer I just assumed a standard factory Motor Home, most which are absorption.
Assume ..makes an ASS out of U & ME but in this case just ME!
Agreed.
I have asked if the PV Logic charger (Solar technologies) can prioritise.Have you checked the setting on the solar controller?
Correct as usual Neil, I just bought a new battery I asked about warrenty told 4 years but had to have voltage of above 8 volts ish ,because their test equipment would not operate below a certain voltage so could not test , warrenty would be declined i, bought the battery over the counter from , Battery group Barnsley , huge battery and solar range in stock , have a google bazzWarranty doesn’t cover taking battery too low which will have happened here Baz.
Our van came with two 110ah lead acid, a 12v 43w fridge but no solar. Useless off grid. Had 1x100 pv fitted, not good enough either, so had second 100pv fitted. Now fine but not in winter when we have often to run the engine on tickover to provide a boost. A battery to battery charger would be a good idea for very fast engine charging, but have not invested so far as they are expensive. We don't have room for any more fixed pv, but portable is a possibility i guess.For offgrid pv 200w+ is essential plus min 200ah+ of bats, lithium if poss. If you want to use 230v equipment then yoy have to go to maybe 400wpv plus large lithiam capacity plus BtoB .Hi All,
Still fairly new to the MH/CV way of life and tbh loving it.
I have a quandary, so just returned from a two week trip around the highlands and islands of Scotland. TBH I am struggling with the leisure battery life (the van and battery are brand new). We want to go off grid for a few days (2-3 tops) at a time and the highlands lend themselves well to this.
However I was finding that the LB (110Ah) would not give us sufficient life. We have a 100W 650wh solar panel but for the first three days in Glen Coe all we saw was rain and no sun, so the LB would never get sufficient to keep it charged up. We even had to resort to driving around for an hr to try and out some juice back into the battery from the engine, but it never really got back up to full strength until we attached it to the EHU for a couple of days. Even longer 2-3 hr drives never saw it back to 13v.
I have asked the coachbuilder who fitted out the van (Peugeot Boxer) to add a second battery but it seems there is no space and they are telling me this cannot be done.
The fridge is the biggest consumer of electric, its a 12v with a tech sheet quoted 3.8A draw, we have LED lights and a Truma - I guess, water pump. Just doing the simple calcs the battery if receiving little or no solar would only last a max of 28hrs (taking it down to dangerous charge levels - which I am not prepared to do) and that is just the fridge alone. We ended up on a few occasions decanting water into water bottles and using torches for light at night. So may as well go back to camping.
Is there anything I am doing wrong OR am I missing something with respect to the charge. I have to say that the van is at home on my drive and the LB charge sitting at 13.4v today with a sunny day.
What are the other solutions available to me to give me extra off grid life. Not really looking to go down the generator route.
Thoughts please.
Many thanks
Jon
You should never run any engine at tickover for long, futher more there will be very little if nothing from the altrnator.Our van came with two 110ah lead acid, a 12v 43w fridge but no solar. Useless off grid. Had 1x100 pv fitted, not good enough either, so had second 100pv fitted. Now fine but not in winter when we have often to run the engine on tickover to provide a boost. A battery to battery charger would be a good idea for very fast engine charging, but have not invested so far as they are expensive. We don't have room for any more fixed pv, but portable is a possibility i guess.For offgrid pv 200w+ is essential plus min 200ah+ of bats, lithium if poss. If you want to use 230v equipment then yoy have to go to maybe 400wpv plus large lithiam capacity plus BtoB .
Just my opinions gatheted over the last mant years which not everyone will second.
Over the last few years I've noticed a few motorhome manufacturers offering compressor fridge set ups with what appears to me to be only enough standalone power for at best one day, I guess they are catering for those who use EHU most of the time. My limited experience of 12v fridges tells me, we need at minimum of 200Ah of battery, 200w of solar, and a B2B, to cover most of our needs and usage.Our van came with two 110ah lead acid, a 12v 43w fridge but no solar. Useless off grid. Had 1x100 pv fitted, not good enough either, so had second 100pv fitted. Now fine but not in winter when we have often to run the engine on tickover to provide a boost. A battery to battery charger would be a good idea for very fast engine charging, but have not invested so far as they are expensive. We don't have room for any more fixed pv, but portable is a possibility i guess.For offgrid pv 200w+ is essential plus min 200ah+ of bats, lithium if poss. If you want to use 230v equipment then yoy have to go to maybe 400wpv plus large lithiam capacity plus BtoB .
Correct, and yes folk say it works harder in summer, but the sun keeps batts up, in winter with much less solar if any around nov/dec it still works as with me i dont do heating much and find the battery will last 24hrs no bother from a full charge.Over the last few years I've noticed a few motorhome manufacturers offering compressor fridge set ups with what appears to me to be only enough standalone power for at best one day, I guess they are catering for those who use EHU most of the time. My limited experience of 12v fridges tells me, we need at minimum of 200Ah of battery, 200w of solar, and a B2B, to cover most of our needs and usage.
Hmm, not sure where you've got that info from but it's not particularly accurate.informstion.
A good summaryHmm, not sure where you've got that info from but it's not particularly accurate.informstion.
A lead acid battery (like ALL battery types) age quicker with deeper discharges.
The more you hammer them with deep discharges the shorter their lives will be. 50% is usually touted as the accepted norm for discharging a lead acid battery before harming it but that's misleading because people think that 50% is ok and 60% is harmful. 60% is harmful but so is 50% and so is 40% for that matter but just not quite so bad, it's a sliding scale. You can discharge to 90% if you need to, there's no limit just a sliding scale of harm that starts at 1%.
Now I know that the graph for damage isn't a straight line, it's curved so it's true that the deeper you discharge the damage increases exponentially but if you're prepared to accept 4 times the damage to get twice as much power from the battery that's probably better than sitting in the dark with no telly just because you've already used 1/2 of the available power and your scared that you'll kill the battery if you take it any lower.
To say a 110Ah battery will be flat after delivering 55Ah is not true unless it's already 50% knackered.
Interestingly there is a sticker on my sargent control panel which says do not discharge below 10.5 volts or it may damage batteries. I have always thought that would be far too low. I wonder why it's there ?Danger below 10.8 they say, im at worst never below 12.2vbut 12.4v is normal when running the fridge over night.View attachment 123150
