mfw
Ok must be old ageSee my post #33
So do I "like" that comment as I have a self-build? Or do I "cry" as I have a Motorhome?Thank heavens for a simple self build.
did you not make little marks on the components to see which got replaced?They have arrived back and to be honest i cannot for the life of me see what they`ve done
I`ve removed both PCB`s from the DS520 box and the PC200 panel to see the reverse sides where all the soldered joints are and they all look exactly the same.
No sign what so ever of any new solder and definitely no new items on either PCB.
The email invoice i received just said " Repair and Upgrade of DS520 and PC200 " with no mention of what the problem was or any individual parts fitted, maybe because it was a " Guaranteed Fixed Price Repair "
It`s bloody freezing up here now so i`m not even going to attempt to refit them yet although tomorrow is forecast warmer.
I`ll report back when fitted how it`s gone.
Ref solder, you don't actually see it done very often, but it used to be the case where the boards were 'washed' with a cleaner to remove flux residues and the like after being worked on and that dulled down any fresh solder so hard to spot reworking.
I know your pain, it's not just Compass, I bought new replacement original LED front and rear roof level side markers(fitted with flying leads) as some of the individual LEDs had failed. Expected a few minute job, undid the 2 external mounting screws and there was Zero free play in the loom. Pull as hard as I dared but no free cable. Gave up in the end as to get to the inside involved stripping out wall panelling.Yes and the marks are still there, i didn`t know they did that to the boards after repairs.
i`m ok with fairly basic electrics but when it comes to removing / adding componants to the PCB`s i`ll leave it to the experts thank you very much.
Very very cold and still damned raining here so i probably won`t get it fitted back in today either because putting heating into the motorhome will mean having to having something open and running an extension so the fan heater will work.
It`s awkward enough where it`s fitted and there`s no give on the cabling which will be very stiff due to the cold weather, the 3 bolt connections for the main cabling to and from the PCB are hidden by the spagetti tangle so they are fitted blind by feel and i can just about get a stubby 10mm spanner up and behind it to tighten them back up without the added problem of numb fingers.
It`s almost like Compass pulled all the wiring tight before doing the final connections as i found out when replacing the outside EHU socket a few years back when the sprung flap cover broke off ........ i`ll just pop a new one on i thought, 10 - 15 minutes, what can go wrong ................................ famous last words
I took the 4 screws out from outside but the socket wouldn`t come more than 2 or 3mm away from the body as if something on the inside was holding it back.
I ended up taking the whole fridge out and dismantling half the bloody kitchen units, that`s when i saw how much tension was on the main EHU cable from the back of the socket to the main taped up wiring loom and was trapped behind the cupboard next to the fridge and had a staple in it.
I replaced it with the same 3 core 2.5mm2 cable that was already on it but gave myself and extra 200mm or so to play with so that if i needed to replace the outside EHU socket again i could do so purely from outside which would then take the 10 - 15 minutes i originally thought.
The cable between the EHU socket at the rear of the fridge and the main wiring loom where it was trapped behind the cupboard next to the fridge was actaully suspended in mid air it was that tight
How the hell it didn`t pull out of the back of the socket in the 9 years we`ve had it from new before the outside flap failed beats me
I guess they pull the cables tight to save money.
I knew a main dealer mechanic who used to do the same with engine oil, what he did not use he took home.
I always leave some slack cable so I have a chance to re-terminate the cable ends.
