And also remember that at least 5% of the pint going in is 'spilt' (charger losses), and another 10% or so is wasted (charging losses aka "Coulombic efficiency"). so for every 100W your Solar Panel may be harvesting, the battery charge will only increase by 85W maximum.Power going into a battery or bank is power going in. Put a pint in a gallon container and put a pint in a five gallon container and you have still only put a pint in.
Remember with a lead acid battery, that last 10% of capacity is hard work to put in.
Where did you read that Lead Carbon charge 8 times faster? Yes, they will charge up usefully and notably faster, but not 8 times faster. With a 130Ah Battery for example, a 150W Panel will not charge a Lead Carbon any faster then a Wet Cell anyway. The PV Panel is the bottleneck there, not the battery.I was unaware of the lead carbon type of battery, looks very interesting.
I've had a couple of Banner 90AH for about 3 years, they've been OK but as has been said they do require the electrolyte level to be monitored and topped up, they're not a sealed battery. I'm guessing that they are nearing the end of their useful life as the multi stage smart charger which I fitted at the beginning of the year always goes to the "recondition" phase when hooked up, before eventually going to "float". The high voltage of the "recondition" stage makes the batteries gas quite a lot (they are well vented!), resulting in even more frequent topping up.
Having read that the lead carbon batteries charge 8 times faster than normal lead acid batteries, I'm wondering whether I could manage with just the one 130AH lead carbon battery with my 150 watt solar panel to keep it topped up. Would the faster charging time compensate to an extent for the lower light levels at this time of year?
Shouldn't go into Recondition as a matter of course. Maybe once a month absolute tops I would want unless you are trying to fix a bad battery.Thanks Wildebus, I know you shouldn't take everything found on an internet search as gospel, but I found that said on a couple of sites - this is one of them, I hope I've understood it correctly http://www.gslithiumbattery.com/news/advantages-and-disadvantages-of-lead-carbon-ba-16165986.html
What do you reckon about the charger going into "recondition" every time? According to the instructions, it should only do that if the "battery test" phase fails after the "absorption" phase is completed.
Just looked at the slightly smaller Ritar 100AH battery on the Alpha site, and they say there " Lead Carbon AGM batteries are true "deep cycle" and can completely re-charge from 4 to 10 times faster than regular lead acid batteries"
Having quoted that I fully acept that you know your stuff Wildebus, and I'm sure that what you say about the PV panel is correct. They don't say in what scenario that sort of charge rate could be achieved!
Mine's active all the time. If such is the case will it be charging SB first and then after fully charging the SB trickle charging the LB?A lot of cigar lighters are only active when the ignition is on
Seems to be a common thing that on cars they are ignition controlled, and on vans always powered? (although having said that, my Ducato one is ignition controlled).Mine's active all the time.
Common misconception.If such is the case will it be charging SB first and then after fully charging the SB trickle charging the LB?
Does the bosch/varta not have a 5 year warrentyWhat do we think of these....
019 Nordstar EFB Carbon Stop Start Car Battery - Alpha Batteries
START-STOP Carbon EFB batteries are intended primarily for vehicles with the START-STOP system. They are also ideal for ordinary cars as […]www.alpha-batteries.co.uk
Not listed as leisure batteries BUT must take some punishment as a stop start battery?
I have the Lead-Calcium battery version of the same battery in my VW LT (went for that version as has 5 year warranty rather than 3 year of the Nordstar Carbon). Seems excellent as a starter.What do we think of these....
Just spotted typo, should be 1500 cycles not 500! With regard to other replies all we use the battery for is Webasto heating/hot water, lighting, fridge and gadget charging.Thanks to all for advice. We were going to go for lithium but in the end settled on a lead carbon battery with 135ah and 500 cycles (194 before discount) from alpha. Our campervan is 9 years old and sassuming she keeps going, likely we may change in ca 10 years when we retire, although will be hard thing to do, so lithium didn't make sense. Thanks again
What physical size are your Banner Batteries? The Leoch Lead Carbon batteries mentioned are very good and would likely fit in their place. The new Ritar batteries are a similar capacity but a higher price - but have a very high charge cycle count and projected service life (15 years) which makes up for that.Very interesting thread, thanks to all the contributors.
I have 2 off 100 Ah Banner batteries, less than a year old, and they dont work as I need them to.
I have a 50A B2B which initially charges them at 40Amps but very soon drops to a paltry 12A, so a journey of 2 hours only puts in about 20 % capacity ( my solar doesnt add much here in winter in Scotland).
Very interested in a couple of lead carbons now, so will follow others experiences with interest, especially as I need good capacity at temps below 0C.
The ritar batteries are 30mm higher than the banners but look far superior for the £200 (-discount) price tag. Please Let us know how you get on!What physical size are your Banner Batteries? The Leoch Lead Carbon batteries mentioned are very good and would likely fit in their place. The new Ritar batteries are a similar capacity but a higher price - but have a very high charge cycle count and projected service life (15 years) which makes up for that.
I will be getting a couple of the 100Ah Ritar Batteries next week when they come into stock![]()
I have just changed my lead acid batteries to lithium they will last longer and hold full voltage for a longer time. In the long run will work out economical.Hi
We have a Bannerbull leisure battery and about to have to replace it for the 3rd time (van is 9 years old).
Majority of our camping is not on sites and never use EHU.
Any suggestions as to what is best battery to replace it with for longer life.
Fiona
You have done well getting 3 years out of your batteries. I use Euro car parts house brand and I am pressed to get 2 seasons use out of them before they hold so little charge as to be useless.Hi
Fiona
These don't look bad value for AGM either...
12v 100AH Platinum AGM Leisure Battery (AGMLB6110L) NCC Class A - Alpha Batteries
Looking for a top quality leisure battery for frequent use off hookup? Look no further. This Platinum 100ah AGM battery […]www.alpha-batteries.co.uk
