Hence I said it must bolt to the front x member, not the body.Shouldn't be an issue unless it's an auto...
Personally I wouldn't be bolting some towing device that someone designed on their kitchen table
to a part of a vehicle that a large automotive manufacturer spent a lot of time and money making deformative and folding towards the occupants of the vehicle to protect them....
The shock loadings that the front structure of a modern vehicle must go through when being towed makes my eyes itch.
Even that isn't designed for towing...Hence I said it must bolt to the front x member, not the body.
'should'If one of the well known A frame suppliers make a pullbar for the MX5 then I should say you are ok but there isn't much info around, strange really because there are so many experts around
The x member has the torque of the engine to road on it, so a tug from a link bar is going to be no problem.Even that isn't designed for towing...
The stresses involved in directions it was never designed to cope with...
Only the towing eye/s are designed to be towed from and even then only for a short duration and for recovery...
Is the direction of force and the frequency of that force...The x member has the torque of the engine to road on it, so a tug from a link bar is going to be no problem.
True but most connect to the flimsy body and not the heavy x member that holds the engine and struts, the other big problem with new cars is they are power steering and thats as stiff as hell without the engine running, some stress that would be.Is the direction of force and the frequency of that force...
Manufacturers only design stuff to do the job its supposed to do...
They don't design stuff with the thought that Mr motorhomer wants to tug their car along using some 3rd party bit of kit behind their behemoth...
Folks WILL obviously do as they like...
So it's no wonder that the front ends fall off Ford KAs etc...
But its a risk I wouldn't want to take OR expose myself to.
Do you really believe that?Manufacturers only design stuff to do the job its supposed to do..
In terms of them only designing components like crossmembers/deformable front end components and towing eyes crumple zones etc etcDo you really believe that?
