Do you have a d+ signal when engine is running?The fridge doesn't work on 12v when the engine is running. I have 12v on the terminal at the back of the fridge with engine running. Is it a case of a new control unit or could it be the led control panel. Any one know good place for parts? Thanks
Ours is the same, dealer has the 12v module on back order, apparently with no idea of timescale for delivery.
Have you tried the spare parts dealers?Ours is the same, dealer has the 12v module on back order, apparently with no idea of timescale for delivery.
It’s a warranty job, so it’s in the dealer’s hands.Have you tried the spare parts dealers?
We had a similar problem with our 2020 , Auto Sleepers. It was controlled by a sergeant unit and had an extra set of fuses in a EM40 fuse box, they have a known fault and even provide a replacement harness ( cheeky gits, should be a recall ) . If you have a similar it could be worth checking.The fridge doesn't work on 12v when the engine is running. I have 12v on the terminal at the back of the fridge with engine running. Is it a case of a new control unit or could it be the led control panel. Any one know good place for parts? Thanks
Unfortunately the only real answer is switch it out for a Thetford 2000 series compressor fridge. The big problem with the large 3 ways is that on 12V they pull a lot of current and most control boards are right on the limit. The other benefit of comp fridge is that the thicker side of 25 a now goes to charging the hab battery when travelling.Yes, meanwhile you wait, I'd ring around and if you find one, tell the dealer, unless your van is in his way, he's not in any rush.
My 2019 AutoTrail was recalled about 10 months ago, and a new fuse box and harness was fitted by the dealer,all done under warrantyWe had a similar problem with our 2020 , Auto Sleepers. It was controlled by a sergeant unit and had an extra set of fuses in a EM40 fuse box, they have a known fault and even provide a replacement harness ( cheeky gits, should be a recall ) . If you have a similar it could be worth checking.
EM40 Rast Repair Harnesses | Sargent Electrical
sargentltd.co.uk
i see there is some info here too.
Sargent EM40 Floor fuse box
I have posted before regarding the above which is found in Auto-trail motorhomes. It may well be in other makes too. I have had 2 burn out in the space of 18 months because they simply are not fit for the purpose when it comes to handling the larger current pull for the large fridges in some...wildcamping.co.uk
I dont have the AS now and it was just out of warranty, this was approx 18 months ago but fortunately i found a thread on a forum as even Sergeant didn't allude to the issue when i phoned them for help. Good to know they are recalling and you got it sorted.My 2019 AutoTrail was recalled about 10 months ago, and a new fuse box and harness was fitted by the dealer,all done under warranty
