trevskoda
Perkins 6354, i worked in AS Bairds commer/roots group back in early seventies,commer walk through van used the 6254 engine though some had the small 4108.I started a diesel engine today - not the campervan, we use that every other week to get the shopping. This engine was originally in a 1960's Commer tipper truck, then spent some years driving a timber winch, before being fitted into a cradle to drive my large rack timber saw bench fitted with a 5 ft yankee circular saw blade many years back. I hadn't used it for about 14 months, its a 6 cylinder Perkins - great engines. It was a little reluctant to start, taking maybe 30 seconds of almost running before coming out of hibernation and spewing its usual cloud of smoke on start-up, running a bit erratic for another minute before settling down to its sweet purring. No glow plugs or inlet pre-heat or easy-start. Amazing for an engine thats had a hard working life of about 55 years! The saw bench itself is probably over 150 years old, though I did modify it maybe 30 years ago to take a bigger blade than it was originally designed for and widened it to take much larger logs. It can cut planks up to 22 inch depth.
Early basic non-electronics diesels are amazingly reliable and economical.
I remember many years ago having a Fordson Super-Dexta tractor, which at the time had no battery. Living at the top of a hill it was easy enough to bump start it ( though embarrassing if you stalled it on the flat). I came to start it one morning, but the wheels just locked. The small drain hole in the exhaust manifold had blocked and rain had come down the silencer and filled 2 of the 3 cylinders causing a hydraulic lock. Took out the injectors, down the hill some more to blow out the water, injectors back in, and it immediately started and ran perfectly.
