I'm done with this thread - Many Thanks to everone who contributed.
For me, this thread is closed as Completed and Successful.
I began the thread with a question, which cropped up when I found myself with a free source of power available, courtesy of the Victron
MPPT Solar Controller's LOAD terminals.
I was expecting to progress with my other jobs and forget about this function, I had no need of it as I thought that the EBL-100 would be managing both batteries when on solar as it does when on a 220v EHU or when driving.
I briefly explored other uses for the load terminals, perhaps to run the 3x way fridge on 12v, or warm up the water in the tank, but I thought that this function would be redundant.
At the time of the question, I was blissfully unaware that my grand design had an omission.
I was mistaken in my understanding of the Schaudtt Elecktroblok EBL-100.1 functionality.
That omission was, when off-grid and stationary, the EBL ONLY charged the leisure batteries from the solar panels and it completely ignores the engine battery. I had a proper schaudtt solar regulator connected into the correct EBL socket but this only passed around 15A to the leisure batteries and zero to the starter battery.
I also had a low level drain on the starter battery, but no method of re-charging it.
So I replaced the Schaudtt PWM solar controller with a Victron Blue Energy MPPT controller, wired directly to the 2x Victron AGM Super Cycle leisure batteries, 460Ah in total.
Panels are 3x80watt & 1x100watt, up on the roof.
A NASA BM1 battery monitor gives me an insight into the status of the leisure batteries and the engine battery voltage.
I ignored the EBL-100 in this new configuration, as it was a bottleneck when used in the conventional and "normal" way.
The same panels can now be expected to give me a max of around 25Amps in bright sunshine available directly to the batteries.
Whereas the Schaudtt solar controller has a max of 15 Amps to inject into the EBL-100.
That is a huge improvement from the same panels just by upgrading the solar controller.
Here was a potential opportunity to answer my own question by using the MPPT load terminals to keep the engine battery topped up.
I figured that I should be able to end up with 2x solar charging sources configured to properly manage each of the different needs for each the starter battery (95Ah lead acid) and the leisure batteries (460Ah AGM super Cycle).
Part of the reason that I have spent so much time in research, discussion, trial and error, is that I have just invested over £1000 in just 2 new leisure batteries and I needed to ensure that they had the best parenting possible.
I wanted to forget about electric when off-grid and not be limited to 3 or 4 days before being forced to drive, just to get re-charged. I had to up-sticks and drive on 3 or 4 occasions on my last adventure around Iberia, so my intention was to remove this as a limitation, Iberia has plenty of free solar energy - gimme.
The remaining limitations of fresh water and waste disposal are the two main influencers to high-quality "loafing in the sunshine" time now that perpetual free solar is in-service and available for me.
Many of the suggestions made here were based upon switching.
Where you only have one source of charge, albeit alternator, ehu or solar and 2 batteries (leisure and engine), there is a case for a switching arrangement for charging both from the same source.
However the switching route is not appropriate in this instance, because :
A) I Have 2 different battery types to manage, lead-acid and AGM Super Cycle. Each of which have hugely different capacities and different charging needs.
The same source cannot be used by both unless the charging profiles could also be switched.
The source power is supplied by the MPPT controller which is configured for AGM. if I then switch the charging onto a lead-acid battery, it will not be getting the correct charging profile.
B) I have a no-cost spare pair of terminals giving away free solar electric at 14v and 14 Amps, so why wouldn't I use this to charge the engine battery ?
The solution was never going to be no-cost, because I need a bridge of sorts between the source and the battery which had to be a proper charger, preferably configurable for specific battery types.
I eventually settled for the Sterling BB1230 DC to DC charger installed in a non-standard way by using the MPPT load terminals as a source for the BB1230 which uses this to properly manage the starter battery.
I won't get into body politics, but the BB1230 is one ugly beast. But it has performed very well and works perfectly with the
Victron MPPT. They work cooperativly in sharing the available solar power to properly charge both batteries independently of each other and each is being charged according to each different needs.
The Schaudtt EBL didn't get an invite to this party, it remains simply to distribute 12v around the van, while off-grid. It's charging functions are not utilised. The standard EBL functionality remains unchanged and are used when driving or on a 220v EHU.
I booted the Sterling on Thursday midday, a dull and grey day with only sparse burst of sunshine breaking through. the panels and the Victron were struggling to scrounge any power.
I also gave the Sterling a knackered starter battery, at 50% depletion, to restore.
Quite a challenge for the new kid on the block.
The afternoon saw the system struggling to make something out of the gloomy light.
The Sterling was getting warm and the cooling fan was cutting in and out for most of the afternoon.
Close of day seen both batteries fully charged.- Success !
Today, Friday started gloomy and improving by mid afternoon with some bright sunshine. More light for the MPPT box to eat.
The Sterling has been silent all day and working happily with the Victron and together they have kept all batteries topped up.
This result is, as I had hoped for, even achieved at such low light levels.
The Sterling probably had the hardest day's work it will ever get, yesterday. Call it an initiation.
Future times should see it only having to maintain an already charged battery, between park ups or long lay-offs.
I intend to reward the Sterling with a new Bosch or Varta engine battery, may they live happily ever after.
The advice, suggestions and comments that have been generated in this thread has been a pleasant and constructive experience which has greatly helped me to arrive at a successful conclusion.
The quality of the inputs and the attention to the details have been of a very high standard. I thank everyone for that, it has helped me to get a result that is looking to exceed my expectations.
And Thank you for the snipers and hecklers, you have been greatly entertaining while at the same time, undermining your own credibility, a feeling called schadenfreude just stroked my Chakras. Thanks again.
Every single proclamation of failure, doom, disaster, etc, has proven to be empty pomposity. Ego, not fact based.
as Sun Szu advises, "Never interrupt your opponent, when they are making a mistake".
Love & Light,
james
Edit / Update Saturday:
I've left time for the system to settle in while I have been keeping a close eye on everything.
I'm more than satisfied with the result, so I did a bit more testing today.
This upgrade has basically ignored the factory fit charging system and is feeding each of the batteries directly and independently of each other.
I have now tested the co-operation of my upgrade with the EBL-100, while on 220V EHU and secondly, when the engine is running.
Everything worked perfectly.
I've already been living full time in the van for the last 3 weeks without the 220v EHU plugged in.
That's all from free solar and my leisure batteries have hardly noticed, now that the engine battery is getting a tan from the sunshine, I can confidently look forward to the PV system providing me with my current daily needs.
I'll be testing a few 220v appliances soon, there are a few things that I would like to use on a regular basis.
NutriBullet for my daily fruit soups, Espresso machine and once a week, a quick go around with the Henry, to clear up after the Jack Russsell has been moulting.
That will obviously deplete the leisure batteries by a lot more than usual but will allow me to give the PV system a bit more work to do.
james
