alwaysared
I will take a look tomorrow, I would probably have to add wood to the outside rails in order to keep everything levelCan you add wood to make centre rail wide enough
Regards,
Del
The first night seemed fine, I'll give it a couple more to help make a decisionMy son has a piece of ply that I will put on top of the slats just try and see if a solid piece would be comfortable enough, I'll let you know tomorrow morning
Regards,
Del
Got some from IKEA casualty corner for 2 quid for a full bed worth. Replaced the flat ones and kept the rest for spares.I have a few bed slats that are split and the the end fittings are also broken and the previous owner screwed them in place! So as a full-timer I think it's important to get the bed right, after all we've spent a small fortune on electrics etc.
So my questions are:
1). Can any suggest a good place to buy replacements?
2). Would I be better off removing all the slats and using one solid piece of ply?
As usual any help and advice is very much appreciated
Regards,
Del
So five nights in and it all seems good so I will be using plywood to make a base and then I'll cut some holes in it, although I keep looking at the Froli system and may still go for thatThe first night seemed fine, I'll give it a couple more to help make a decision
Regards,
Del
Frail system is costly but I've never heard a bad word against it delSo five nights in and it all seems good so I will be using plywood to make a base and then I'll cut some holes in it, although I keep looking at the Froli system and may still go for that
Regards,
Del
Hi,I have a few bed slats that are split and the the end fittings are also broken and the previous owner screwed them in place! So as a full-timer I think it's important to get the bed right, after all we've spent a small fortune on electrics etc.
Regards,
Del
