trevskoda
No you heat them twice with accet torch to they glow red.Problem with brake fluid change thay can brake bleed nipples, then new callipers needed .
My garage has just changed the brake fluid in my 'van, as well as replacing two corroded brake lines, and the mechanic lightly tapped the nipples with a small hammer before releasing them. This he assures me is the preferred technique. Give them a shock , as he put it.No you heat them twice with accet torch to they glow red.
couple of times i've welded nuts to the nipples - does the trickNo you heat them twice with accet torch to they glow red.
If they have been there for years heat is the only way, mind you i would be changing back cyl every few years, from calipers if looked after will last a long time, teflon spray behind the seals keeps the pistons free and no corrosion, working them in and out with a steel bar or caliper squeezer is a good idea when pads are out, carfull not to pop the pistons.My garage has just changed the brake fluid in my 'van, as well as replacing two corroded brake lines, and the mechanic lightly tapped the nipples with a small hammer before releasing them. This he assures me is the preferred technique. Give them a shock , as he put it.
Indidentally after four years since the fluid was changed the brakes no longer have a sightly spongy feel.
The garage my Motorhome is in at the moment for its MOT tested one of my self-builds a few years ago and failed it on the numberplate light. once they finished the test, they put a new bulb in and then immediately passed it -so I had a fail and a pass around 5 minutes apartor Arnold Clark this week who didn't say
"One of your number plates lights was blown, we've popped a new one in foc"
Instead I have a written quote for replacing it.
Labour 0.2 hours =£24
Part = £20.63
Total = £44.63
Plus VAT= £53.56
It was the heat that sorted them, nothing to do with your nuts.luckily i've done most things to a car ,mechanically, so i can talk the talk to garages ,
AS im sure you know test centres here do not fix anything, a bulb out meens a trip home or garge to fix then a reduced resit at the gov centre, this is to stop back street mafia wingleing the sys.The garage my Motorhome is in at the moment for its MOT tested one of my self-builds a few years ago and failed it on the numberplate light. once they finished the test, they put a new bulb in and then immediately passed it -so I had a fail and a pass around 5 minutes apart
I asked why they didn't just swap the bulb and do a pass and apparently all these tests are timed so couldn't (plus of course no repairs are allowed as soon as the test is started).
Oh - and no charge for the bulb either.![]()
I used to think that was a good idea until I had an incorrect fail from a centre like that. Never been back to a council centre again!AS im sure you know test centres here do not fix anything, a bulb out meens a trip home or garge to fix then a reduced resit at the gov centre, this is to stop back street mafia wingleing the sys.
I had 2 here and pulled them, got sorted by manager once we got talking in his office and he found i knew what i was talking about, hard to fool a fool.I used to think that was a good idea until I had an incorrect fail from a centre like that. Never been back to a council centre again!
I had a similar incident on my 3 yr old Honda 125. Failed it for loose nut (a Nylock nut!) on brake lever. Informed me of the failure and said they would carry out a FOC workshop repair for me. I watched him tighten the nut 1/2 a turn , with a spanner he already had in his pocket, and preceded to pass the MOT. Im not sure he thought he needed to be awkward but there we go. (Do they need a number of failures to make the garage pass/fail stats look good for VOSA ?) Obviously didn't need my business next year which he of course he succeeded in accomplishing.The garage my Motorhome is in at the moment for its MOT tested one of my self-builds a few years ago and failed it on the numberplate light. once they finished the test, they put a new bulb in and then immediately passed it -so I had a fail and a pass around 5 minutes apart
It maybe they had just had inspection and was unsure if you were a secret shopper looking to catch them out.I had a similar incident on my 3 yr old Honda 125. Failed it for loose nut (a Nylock nut!) on brake lever. Informed me of the failure and said they would carry out a FOC workshop repair for me. I watched him tighten the nut 1/2 a turn , with a spanner he already had in his pocket, and preceded to pass the MOT. Im not sure he thought he needed to be awkward but there we go. (Do they need a number of failures to make the garage pass/fail stats look good for VOSA ?) Obviously didn't need my business next year which he of course he succeeded in accomplishing.
If you can get your nipples close to your nuts, you need to reduce the size of your man boobs ...It was the heat that sorted them, nothing to do with your nuts.![]()
The MOT garage that I use is very trustworthy but they are in the minority, if it fails on something simple they fix it FOC, I haven't bought a bulb in 10 years"Your pads need replacing but don't worry, your brake discs are fine."
I've lost count of the times I've been told with a grave expression, "oh yes, your discs are corroded/pitted/scored, I'm afraid they'll need replacing too."
Are we being ripped off?
They are not allowed to make ANY changes or adjustments - he did exactly what he should do and did not do what would have been better for you AND easier for him as he was simply not allowed to.Im not sure he thought he needed to be awkward but there we go. (Do they need a number of failures to make the garage pass/fail stats look good for VOSA ?) Obviously didn't need my business next year which he of course he succeeded in accomplishing.
Not disputing that, more that the fault didn't really exist, he chose to invent it and conveniently had the correct spanner in his hand to correct it! When back home I check, it was possible to tighten or losen this nyloc nut a couple of turn in either direction with little if any effect. What he did, did nothing. Anyway a FOC repair winner winner chicken dinner! I lack gratitudeThey are not allowed to make ANY changes or adjustments - he did exactly what he should do and did not do what would have been better for you AND easier for him as he was simply not allowed to.
DVLA/DVSA/VOSA/DoT/whoever polices MOT inspections have undercover inspectors and if there happened to be one there during your MOT, the garage could be in danger of losing their license.
What happened to remedial pads that Ford pioneered in the 80s they had a surface of carborundum grit to clean up the discs ? I make up my own now with carborundum powder and 2 pack epoxy."Your pads need replacing but don't worry, your brake discs are fine."
